串口3重映射问题
4060|5
 楼主| song19881218 发表于 2012-7-18 15:11 | 显示全部楼层 |阅读模式
串口3重映射到PC10,PC11现在只能发送,但是进不去接收中断,求助,上代码
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
   GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
   GPIO_Init(GPIOC, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
DMA_DeInit(DMA1_Channel2);
DMA_tx_USART3_Configuration(1);
USART_InitStructure.USART_BaudRate = 9600;
   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
   USART_InitStructure.USART_StopBits = USART_StopBits_1;
   USART_InitStructure.USART_Parity = USART_Parity_No;
   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
   USART_InitStructure.USART_Mode = USART_Mode_Rx |   USART_Mode_Tx;
   USART_Init(USART3, &USART_InitStructure);
    USART_DMACmd(USART3,USART_DMAReq_Tx, ENABLE);
   DMA_Cmd(DMA1_Channel2, ENABLE);
USART_ITConfig(USART3, USART_IT_ERR, ENABLE);
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
   USART_Cmd(USART3, ENABLE);
 楼主| song19881218 发表于 2012-7-18 17:44 | 显示全部楼层
咋没人回答啊?
捡漏王子 发表于 2012-7-18 20:50 | 显示全部楼层
你串口中断打开没?
figo20042005 发表于 2012-7-18 21:46 | 显示全部楼层
接收中断打开,进入中断接收
 楼主| song19881218 发表于 2012-7-19 16:34 | 显示全部楼层
4# figo20042005
这个不就是开接收中断的,倒数第二句
logokfu 发表于 2012-7-19 19:35 | 显示全部楼层
stm32f10x_it.c 这里文件里面的中断函数你写了吗
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles USARTx global interrupt request.
  * @param  None
  * @retval None
void USART1_IRQHandler(void)
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    RxBuffer[RxCounter++] = (USART_ReceiveData(USART1) & 0x7F);
    if(RxCounter == NbrOfDataToRead)
      /* Disable the USART1 Receive interrupt */
         USART_SendData(USART1, TxBuffer[TxCounter++]);
      USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
  if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
    /* Write one byte to the transmit data register */
    if(TxCounter == NbrOfDataToTransfer)
      /* Disable the USART1 Transmit interrupt */
      USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
