DaVinci DM6437 中文教程(2)
2594|1
 楼主| gaochy1126 发表于 2012-7-19 18:27 | 显示全部楼层 |阅读模式
二、DaVinci DM6437 学习资料
SPRU978 — TMS320DM643x DMP DSP Subsystem Reference Guide. Describes the digital signal
processor (DSP) subsystem in the TMS320DM643x Digital Media Processor (DMP).
SPRAA84 — TMS320C64x to TMS320C64x+ CPU Migration Guide. Describes migrating from the
Texas Instruments TMS320C64x digital signal processor (DSP) to the TMS320C64x+ DSP. The
objective of this document is to indicate differences between the two cores. Functionality in the
devices that is identical is not included.
SPRU732 — TMS320C64x/C64x+ DSP CPU and Instruction Set Reference Guide. Describes the CPU
architecture, pipeline, instruction set, and interrupts for the TMS320C64x and TMS320C64x+ digital
signal processors (DSPs) of the TMS320C6000 DSP family. The C64x/C64x+ DSP generation
comprises fixed-point devices in the C6000 DSP platform. The C64x+ DSP is an enhancement of
the C64x DSP with added functionality and an expanded instruction set.
SPRU871 — TMS320C64x+ DSP Megamodule Reference Guide. Describes the TMS320C64x+ digital
signal processor (DSP) megamodule. Included is a discussion on the internal direct memory access
(IDMA) controller, the interrupt controller, the power-down controller, memory protection, bandwidth
management, and the memory and cache.
Asynchronous External Memory Interface EMIF SPRU984
DDR2 Memory Controller DDR2 SPRU986
DSP Megamodule—Internal Direct Memory Access IDMA SPRU871
Controller
DSP Megamodule—Interrupt Controller INTC SPRU871
DSP Megamodule—Power-Down Controller PDC SPRU871
DSP Subsystem—Phase-Locked Loop Controller PLLC SPRU978
DSP Subsystem—Power and Sleep Controller PSC SPRU978
Enhanced Direct Memory Access Controller EDMA SPRU987
Ethernet Media Access Controller/ EMAC/MDIO SPRU941
Management Data Input/Output Module
General-Purpose Input/Output GPIO SPRU988
High-End CAN Controller HECC SPRU981
Host Port Interface HPI SPRU998
Inter-Integrated Circuit Module I2C SPRU991
Multichannel Audio Serial Port McASP SPRU980
Multichannel Buffered Serial Port McBSP SPRU943
Peripheral Component Interconnect PCI SPRU985
Pulse-Width Modulator PWM SPRU995
Timer, 64-bit Timer SPRU989
Two-Level Internal Memory Cache SPRU862
Universal Asynchronous Receiver/Transmitter UART SPRU997
VLYNQ Port VLYNQ SPRU938
Video Processing Back End VPBE SPRU952
Video Processing Front End VPFE SPRU977
梅花望青竹 发表于 2012-7-19 18:35 | 显示全部楼层
学习了,不错的资料!
