[STM8] 編譯出錯exit code=1.
3312|8
 楼主| xueweianying 发表于 2012-7-20 14:52 | 显示全部楼层 |阅读模式
開發環境STVD  默認芯片STM8S208MB改為STM8S903K3,編譯出錯誤,請高手幫忙。
Compiling mc_fwlib_scalar\src\mc_statemachine.c...
cxstm8 +warn +modsl -x -no +compact +split -pne -ga -oc -ov -pcp +fast -pnc -gna +strict -pp -pnc -pnp -prb -ps -psa -pu -pc99 -v -l -e -i"..\..\stm8 builder\stm8_mc_framework\param" -i"..\..\stm8 builder\mc_fwlib_scalar\param" -i"c:\documents and settings\gdwei.ccg\my documents\stm8 builder\stm8_mc_framework\param" -i"c:\documents and settings\gdwei.ccg\my documents\stm8 builder\mc_fwlib_scalar\param" -istm8_mc_framework\inc -iMC_FWLIB_SCALAR\inc -iMC_FWLIB_SCALAR\param -iSTM8_FWLIB\inc -iSTM8_MC_FRAMEWORK\inc -iSTM8_MC_FRAMEWORK\param -i"C:\Program Files\COSMIC\CXSTM8_32K\Hstm8"  -clSTVD_COSMIC_Release\ -coSTVD_COSMIC_Release\ mc_fwlib_scalar\src\mc_statemachine.c
macros compact and fast are exclusive
The command: "cxstm8 +warn +modsl -x -no +compact +split -pne -ga -oc -ov -pcp +fast -pnc -gna +strict -pp -pnc -pnp -prb -ps -psa -pu -pc99 -v -l -e -i"..\..\stm8 builder\stm8_mc_framework\param" -i"..\..\stm8 builder\mc_fwlib_scalar\param" -i"c:\documents and settings\gdwei.ccg\my documents\stm8 builder\stm8_mc_framework\param" -i"c:\documents and settings\gdwei.ccg\my documents\stm8 builder\mc_fwlib_scalar\param" -istm8_mc_framework\inc -iMC_FWLIB_SCALAR\inc -iMC_FWLIB_SCALAR\param -iSTM8_FWLIB\inc -iSTM8_MC_FRAMEWORK\inc -iSTM8_MC_FRAMEWORK\param -i"C:\Program Files\COSMIC\CXSTM8_32K\Hstm8"  -clSTVD_COSMIC_Release\ -coSTVD_COSMIC_Release\ mc_fwlib_scalar\src\mc_statemachine.c" has failed, the returned value is: 1
exit code=1.
STM8_STVD_COSMIC_BLDC.elf - 1 error(s), 0 warning(s)
IJK 发表于 2012-7-20 15:34 | 显示全部楼层
先看看编译器路径之类设置得是否正确。
 楼主| xueweianying 发表于 2012-7-21 08:18 | 显示全部楼层
2# IJK
路径设置没有问题啊
 楼主| xueweianying 发表于 2012-7-23 10:07 | 显示全部楼层
还有其它方法解决吗?请高手指点!
 楼主| xueweianying 发表于 2012-7-23 10:11 | 显示全部楼层
其实仅仅是改变了默认芯片(STM8S208MB改為STM8S903K3)其它的设置没有任何改变,默认芯片是没有错误得。。。
figo20042005 发表于 2012-7-23 11:01 | 显示全部楼层
你这个错误提示还真是长
weigd 发表于 2012-7-23 12:05 | 显示全部楼层
沒人解答?
頂一下!
weigd 发表于 2012-7-24 17:21 | 显示全部楼层
版主有何高見..
weigd 发表于 2012-7-25 17:44 | 显示全部楼层
求香版主幫助???
