PWM直流电机捕获频率的问题
1980|1
 楼主| iplayboy 发表于 2012-7-25 17:29 | 显示全部楼层 |阅读模式
求解答:
void TIM2_IRQHandler(void)
  if(TIM_GetITStatus(TIM2, TIM_IT_CC1) == SET)
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);//清除中断位
    if(CaptureNumber == 0)
      IC3ReadValue1 = TIM_GetCapture2(TIM2); //捕获输入脉冲
      CaptureNumber = 1;
    else if(CaptureNumber == 1)
      IC3ReadValue2 = TIM_GetCapture2(TIM2);
      if (IC3ReadValue2 > IC3ReadValue1)
        Capture = (IC3ReadValue2 - IC3ReadValue1);
      else
        Capture = ((0xFFFF - IC3ReadValue1) + IC3ReadValue2);
   //频率计算
  //Capture = (IC3ReadValue2 - IC3ReadValue1)*100/ Capture;
      TTIM2Freq = (uint32_t) SystemCoreClock / Capture;
      CaptureNumber = 0;
为什么TIM_GetCapture2(TIM2)捕获的时间一直是0呢? IC3ReadValue2和 IC3ReadValue1一直是0,不知道为什么?
 楼主| iplayboy 发表于 2012-7-25 18:06 | 显示全部楼层
没人知道吗?
