关于msp430测频率的问题
3796|5
dong130300|  楼主 | 2012-7-27 15:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我使用g2335的P1.2作为定时器TIMEA_0的捕获输入端,但是再看数据手册是的时候发现如图的描述,看有的资料说要选择P1.2的第二功能,但是怎么看TIMEA_0是这个管脚的第几功能啊,并且我还用到这个管脚的外部中断功能,应该是先进入普通的IO中断,当溢出之后进入定时器中断这是我配置的管脚
P1DIR&=~BIT2;
P1IES&=~BIT2;
P1SEL = BIT2 ;
这是用到的中断向量
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A (void)
#pragma vector=PORT1_VECTOR
__interrupt void P1_ISR (void)
但是程序就是进不去中断
已经弄了很久了,希望大家帮忙啊
http://file:///C:%5CUsers%5Cadmin%5CAppData%5CRoaming%5CTencent%5CUsers%5C1147833968%5CQQ%5CWinTemp%5CRichOle%5C]UL75M3R%7B0CE3MSVFYMKSB9.jpg
        这是我的程序#define uint unsigned int
#define uchar unsigned char
uint Period; //==用于存放周期==
unsigned long int TA_OverflowCnt;
unsigned char frequency; //==用于存放频率==
uint fy[7];
void process(void);
void delay();
void PWM(void);
void main( )
    WDTCTL = WDTPW+ WDTHOLD;  //stop WDT
    BCSCTL1=CALBC1_1MHZ;
    DCOCTL=CALDCO_1MHZ;
    P1DIR=BIT0+BIT1+BIT5+BIT3+BIT4;//控制液晶用的
    P1DIR&=~BIT2;
    P1IES&=~BIT2;
    P1SEL = BIT2 ;
  P1SEL2 =BIT2 ;
    BCSCTL3 |= LFXT1S_0;                      // LFXT1 = VLO
    IFG1 &= ~OFIFG;                           // Clear OSCFault flag
    BCSCTL2 |= SELM_0 + DIVM_0 + DIVS_0;      // MCLK = DCO, SMCLK = DCO
    lcd_init();
//  lcd_write_stringxy(1,0,"ADC result");
    _EINT();
    while(1)
         PWM();
         P1IE|=BIT2;        //    开启I/O中断,连续计数模式、无分频、开启定时中断
         TACTL=TASSEL_1+MC_2+TAIE+TACLR+ID_0;  //TA基准时钟为32768HZ
         process();
         LCD_Disp_Num(0,3,fy[5]);
         LCD_Disp_Num(6,3,fy[4]);
         LCD_Disp_Num(12,3,fy[3]);
         lcd_write_stringxy(18,3,".");
         LCD_Disp_Num(24,3,fy[2]);
         LCD_Disp_Num(30,3,fy[1]);
         LCD_Disp_Num(36,3,fy[0]);
         lcd_write_stringxy(42,3,"KHZ");
void process(void)
            frequency=Period/(1/32768);
             fy[6]=frequency/1000000;
             fy[5]=(frequency-1000000*fy[6])/100000;
             fy[4]=(frequency-1000000*fy[6]-100000*fy[5])/10000;
             fy[3]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4])/1000;
             fy[2]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3])/100;
             fy[1]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3]-100*fy[2])/10;
             fy[0]=frequency%10;
void PWM(void)
  P2DIR |= BIT2;                                // 选择P2.2的第二功能,即TA1.1
  P2SEL |= BIT2;
  TA1CCR0 = 199;                             // PWM Period
TA1CCTL1 = OUTMOD_7;                         // CCR1 reset/set
  TA1CCR1 = 100;                               // CCR1 PWM duty cycle
  TA1CTL = TASSEL_2 + MC_1;                  // SMCLK, up mode
//  I/O中断程序
    static unsigned int i=0;            //   I/O中断计数值
    if(P1IFG&BIT2)
        i++;
    if(i>=100)                     //    计数100次
        i=0;
        Period=(((unsigned long int)TA_OverflowCnt)<<16)+TAR;     //   获得100个周期内的时钟个数
        TA_OverflowCnt=0;
        TACTL|=TACLR;            //   定时清零
    P1IFG=0;
//   Timer_A中断程序
#pragma vector=TIMER0_A0_VECTOR                //改过了
        switch(TAIV)                //  TA中断方式选择
        case 2:break;
        case 4:break;
        case 10: TA_OverflowCnt++;    //    溢出中断计数加1
                 break;
tianjiantian| | 2012-7-27 16:14 | 只看该作者
把#pragma vector=TIMER0_A0_VECTOR改为
#pragma vector=TIMER0_A1_VECTOR
试试。。
tianjiantian| | 2012-7-27 16:15 | 只看该作者
应该是:#pragma vector=TIMER1_A0_VECTOR,我也是初学者。。。嘿嘿
dong130300|  楼主 | 2012-7-27 16:20 | 只看该作者
谢谢你啊,但是不管用啊,我觉得P1.2不是TIMEA_0的捕获输入口吗,中断向量应该是#pragma vector=TIMER0_A0_VECTOR吧,而且我硬件调试的时候连IO口中断都进不去
tianjiantian| | 2012-7-27 16:20 | 只看该作者
P1SEL = BIT2 ;
  P1SEL2 =BIT2 ;
个人认为:P1SEL |=BIT2;就行了。。看一下用户手册
dong130300|  楼主 | 2012-7-27 16:42 | 只看该作者
我看了,我写的那个语句是实现那个引脚的第二功能,但是我在数据手册没看到他的第二功能是什么,那张图片是我在数据手册上的截图
