[AVR单片机] MEGA32下的HC595驱动,已测试
2619|0
 楼主| icecoffelin 发表于 2009-4-27 23:27 | 显示全部楼层 |阅读模式
MEGA32下的HC595驱动,已测试
#ifndef _HC595_H
#define _HC595_H
//SPI initialize
// clock rate: 250000hz
void spi_init(void)
DDRB |= (1<<PB5) | (1<<PB7) | (1<<PB4);   /* 设置MOSI 和SCK 为输出,其他为输入 */
SPCR = (1<<SPE) | (1<<MSTR)
   | (1<<SPR1) | (1<<SPR0);   /* 使能SPI主机模式,设置时钟速率为fck/128 */
#pragma interrupt_handler spi_stc_isr:13
void spi_stc_isr(void)
//byte in SPDR has been sent/received
/*SPI数据发送*/
void SPI_MasterTransmit(unsigned char i)
SPDR = i;        /* 启动数据传输 */
while (!(SPSR & (1<<SPIF))); /* 等待传输结束 */
/*595数据输出*/
void SPI_595_Out(unsigned int i)
    uint j;
PORTB &= ~(1 << 4);      /*准备锁存*/
SPI_MasterTransmit(i>>8);
SPI_MasterTransmit(i);
PORTB |= (1 << 4);      /*锁存数据*/
void write595(unsigned char DATA) //写数据到74HC595函数
uchar i;
SPDR=DATA; //开始发送数据
//while((SPSR>>7)==0); //等待发送接收结束
while(!(SPSR & (1<<SPIF))) ;
i=SPDR; //读,是为了清零中断标志
void TurnOnDigitalOutput(uchar n)
    if ( n>16 ) return;
DigitalOutputStatus[n] = 1;
DATA_74HC595 |= (0x0001<<n);
SPI_595_Out(DATA_74HC595);
void TurnOffDigitalOutput(uchar n)
    if ( n>16 ) return;
DigitalOutputStatus[n] = 0;
DATA_74HC595 &= ~(0x0001<<n);
#endif
