STM32 SPI3与SPI2通信问题
8550|2
 楼主| yshiliu 发表于 2012-7-31 10:11 | 显示全部楼层 |阅读模式
今天用ST-Link调试STM32F103ZET6中的SPI3和SPI2通信,我将开发板上的SPI3和SPI2对应的MISO、MOSI,SCLK,NSS用导线连接。编译过程没有错误,但用STlink调试运行到SPI_Cmd(SPI2,ENABLE);时,就出现一个错误对话框:Internal command error,然后出现错误对话框:Error while attempting to read 64 bytes from 0x2000006e4。
    初始化代码如下:
  1. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_USART1 | RCC_APB2Periph_SPI1, ENABLE);
  2.   /* USART2,USART3,UART4 Periph clock enable */
  3. RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 | RCC_APB1Periph_USART3 | RCC_APB1Periph_UART4, ENABLE);
  4. RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  5. RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
  1. /* Configure SPI3 pins: SCK, MISO and MOSI */
  2. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
  3. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  4. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  5. GPIO_Init(GPIOB, &GPIO_InitStructure);
  6. /* Configure SPI2 pins: SCK, MISO and MOSI */
  7. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  8. GPIO_Init(GPIOB, &GPIO_InitStructure);
  1. void SPI_Configuration(void)
  3.     SPI_InitTypeDef   SPI_InitStructure;
  4.     /* SPI1 Config -----------------------------------------*/
  5.     SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  6.     SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  7.
  8.     SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  9.     SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  10.     SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  11.     SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  12.     SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  13.
  14.     SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  15.     SPI_InitStructure.SPI_CRCPolynomial = 7;
  16.     SPI_Init(SPI3, &SPI_InitStructure);
  17.     /* Enable SPI3 */
  18.     SPI_Cmd(SPI3, ENABLE);      //执行这句的时候就出现我上面描述的问题
  19.     //SPI_ITConfig(SPI3, SPI_IT_RXNE, ENABLE);
  20.   //使能SPI1接收中断
  21.     /* SPI2 Config -------------------*/
  22.     SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  23.     SPI_Init(SPI2, &SPI_InitStructure);
  24.     SPI_Cmd(SPI2, ENABLE);
  25. }
请问大家这是什么问题呢,昨天弄了一下午,也没弄出来。是接线的问题么?
还有一个问题要请教一下:我看到SPI配置寄存器CR1是32位的,前16bit是保留的,后16bit是定义的。但在SPI_TypeDef中是这样定义的
  1. typedef struct{  vu16 CR1;  u16 RESERVED0;  vu16 CR2;  u16 RESERVED1;  vu16 SR;  u16  RESERVED2;  vu16 DR;  u16  RESERVED3;  vu16 CRCPR;  u16 RESERVED4;  vu16 RXCRCR;  u16  RESERVED5;  vu16 TXCRCR;  u16  RESERVED6; } SPI_TypeDef;
这不就用了高寄存器中的高16bit来定义了么?
feilusia 发表于 2013-9-5 11:14 | 显示全部楼层
LZ弄明白了嘛?我也出现这个问题了!!
airwill 发表于 2013-9-5 13:38 | 显示全部楼层
从定义看,  CR1 应该是 16 位方式访问.
这条错误里提到的内存地址是 SRAM 中.
会不会与 SPI 无关?
