[产品供应] 工业控制、电子仪器仪表、航空航天所必需的电子连接器
1538|0
 楼主| hichen888 发表于 2012-8-1 11:34 | 显示全部楼层 |阅读模式
ERNI ERmet连接器、EPT工业控制及通讯连接器、3M MDR连接器、XMULTIPLE网络连接器、TE/AMP连接器、HRS连接器、WINCHESTER连接器、FOXCONN主机板连接器
A Type
TYPE A Connector
110 signal contacts
44 shield contacts
50mm long including the multifunction area for coding keys
Integral pre-alignment guide and polarizing pins
Optional locating pegs for printed circuit board(PCB)mounting
3 contact lengths for sequential mating
B Type
TYPE B Connector
125,110 and 95 signal contacts
50 shield contacts
50mm,44mm and 38mm long without the multifunction area
C Type
Type C Connector
55 signal contacts
22 shield contacts
25mm long
For end positions only
Pre-alignment guide pins
Optional locating pegs for printed circuit board(PCB) mounting
AB Type
Type AB Right Angle Female
110
95signal contacts
40 and 32 shield contacts
44mm and 38mm long
Integral prealignment guide and polarizing pins
AB compatible males also available
MetalCoverHood)
D-SUB Metal Cover(Hood) With Short Scres
?? No. of Contacts
09 , 15 , 25 , 37 , 50
?? Special Function
A: Standard
B: Thumbscrew
C: With Grommet
D: With Slide Lock Post
?? Screw Type
A: #4-40 Unc (Standard)
D-SUB Crimp Type
D-SUB Crimp Type
Insulator : Glass-Filed Thermoplastic PBT, UL94V-0 rated
* Shell : Steel, 100u Tin Over 50u min Nickel.
* Clinch Nut : Brass, 100u min Nickel Plated.
* Screwlock : Brass, 100u min Nickel Plated.
Electrical:
* Insulation Resistance : 1000 magohms at 500 VDC.
* Dielectric Withstanding Voltage : 1000 VAC/rms 60Hz for 1 minute
D-SUB Machine Pin
Electrical:characteristic contact current rating:3A
Contact resistance:25 mohm max 10 secinsulation
Resistance:5000 mohm min.at DC500V.dielectric with standing.
Voltage:AC 1000v 1 minute r.m.soperating
Temperature:-55°C~+105°C
Finishes contact:3u
Shell:nickel plated
D-SUB铆鱼叉
ELECTIRAL:
1.Current Rating:5 AMP PERES
2.Dielectric With Standing Voltage:AC 1000V r.m.s
3.Insulation Resistance:5000 Megohms Min at DC 500V
4.Contact Resistance:30MΩ MAX
MATERIAL:
1.Insulator:Thermoplastic With G.F.,UL 94V-0
2.Contact:Cooper Alloy
3.Shell:Stell
ENVIRONMENT:
1.Solderbility:Meet With MIL-STD-202E,Method 208C TEM.of Test 245°C±5°C For Five Section
2.Operating Temperature:-55°C To +125°C
D-SUB Coax-Contacts
D-SUB Coax-Contacts
1W1/2W2/2V2/3W3/3V3/5W5/5W1/7W2/7W7/8W8/9W4/13W3/13W6/
17W2/17W5/21W1/21W4/24W7/25W3/27W2/36W4/43W2/47W1
The 50 ohmcoaxial connector systemcombines the benefits ofthe rectangular DUALOBE connectors while offeringthe flexibility to terminateup to nine coaxial contactswithin the same metal connector housing.Furthermore, with thisunique design, five signal contacts, terminatedwith 30 AWG or smaller discrete wire, can also beintegrated into this connec-tor package.These connectors are typicallyused in applications withfrequencies up to 20 GHz.RG-178 coax coaxial cableis the standardcable usedon these connectors. Thereceptacle coax connectoris also available in a horizontal surface mount configuration allowing forwire to board applications.Harness assemblies andcustom configurations canalso be accommodated
D-SUB High Current Contacts
?? Pressfit has a low failure rate only wire wrap technology is better.
?? New generation with stamped high current contacts.
?? Several machined contacts for crimping, soldering and pressfit.
?? Suitable for cable connector housing series KSG 183, KSG 185 and KSG 200.
?? Partial loadings of power and signal contacts.
ZD High Speed Connector
Design:Wafers with individually shieded pairs of contacts.
Contacts:Low noise,dual beam,leaf contacts with one ground blade for every pair of signals.
Wafer pitch:2.5mm from wafer to wafer
Pitch between signal pins:1.5mm between pairs (within wafer).
Pitch between pairs:4.5mm (within wafer).
Ground arrangement:In line with signals at termination and surounding shield.
Multiline Crosstalk:<5% at 100ps rise time,250mV swing.
Reflection factor:<10% including printed circuit board termination.
Differential Impedance:100Ω
Impedance to ground:50Ω
Keying Module:Standard colored deys acc.to IEC 61076-4-101.
Power Modules:Closed entry,vertical female backplane modules with stamped blades.
Alignment Features:Improved pre-alignment guide and polarizing features,4 riged blades for all modules.
Modularity:Modules are available in two widths and avariety of lengths to integrate within typical Eurocard designs utilizing 5 and 8 row,2mm HM connectors acc.to IEC 61076-4-101.
Right Angle Male
Right Angle Male
The ERmet ZD right angle male connector provides in the 10 wafer version 20 to 40 contact pairs and is available with pressfit temination.The connector is designed for high speed differential applications and is an extension of the ERmet 2 mm HM product line.
Vertical Female
Vertical Female
In addition to the four-pair connector modules specified for use in AdvancedTCA? Zone 2,the product line includes two-pair and three-pair signal modules and coplanar connectors.A mezzanine style connector is also available in a four-pair version(vetical female pressfit).
Future Bus
Technical data
Future Bus Connector Signal Power
Housing Liguid Crystal polymer(LCP) UL 94V-0
Contact
  Male:Brass
Female:Phosphor Bronze
Press Fit Type:Phosphor Bronze
Operating Temperature -65°C
+125°C
Contact Resistance 30m(ohm)max.at DC 500V
Insulator Resistance 1000M(ohm)min.at DC 500V
Current Rating 1 AMP 3 AMP
Withstanding Voltage AC 500V for 1 minute
Insertion Force 0.45N max.per individual contact 1.5N max.per individual contact
Withdrawal Force 0.2N min.per individual contact 0.5N min.per individual contact
Contact retention in housing Female=5N ,Male=10N
MX125
The MX125 1.25mm (.049") pitch system is designed for high-density harness applications. PicoBlade provides the same 1.0 amperes of current as similar 2.00mm (.079") pitch systems, but in a more compact design.
MX125 is offered in wire-to-board and wire-to-wire options. The system saves about 45% of PCB space compared to typical 2.00mm wire-to-board systems. It is a single row system, available in 2 to 15 circuits, with both surface mount and through-hole
headers.A full range of automatic, semi-automatic and manual tooling is available to support crimp harness assembly using discrete wires.
Specifications:
Current rating:1A AC,DC
Voltage rating:125V AC,DC
Temperature range:-25°C~+85°C
Contact resistance:20Mohm Max.
Insulation resistance:100Mohm Min.
Withstanding voltage:500V AC/minute.
2021
2.00mm pitch wire to board connector
Specifications:
Current rating:2A AC,DC
Voltage rating:100V AC,DC
Contact resistance:10Mohm Max.
Insulation resistance:1000Mohm Min.
Withstanding voltage:800V AC/minute.
PHD
Specifications:
Current rating:3A AC,DC
Voltage rating:250V AC,DC
2532
2.50mm pitch wire to board connector
Specifications:
Withstanding voltage:1000V AC/minute.
MX2.54
2.54 pitch wire to board connector
SL (Stackable Linear) is a modular, single row, wire-to-wire and wire-to-board system.
The system includes:
Low profile latching vertical and right angle headers.
Five stackable, low profile housing for male or female crimp terminals.
Pre-assembled, single piece pin and receptacle connector assemblies for IDT termination of discrete wire or ribbon cable and
piercing crimp termination of FFC/FPC.
Single and dual row latching interim clips for stacking of subassemblies to form larger connectors.
Panel mounts for modular wire-to-wire remote interconnections.
These product families are suitable for low power signal applications such as computers, medical instruments, and automotive
Specifications:
Withstanding voltage:1500V AC/minute.
各种连接器平价供应。
获得更多资讯,索取更多资料
北京海辰博创科技有限公司
010-60606267  13718719010  翁sir
010-62712788
www.hichen-tech.com
info@Hichen-tech.com
