[产品供应] ERNI ERmet连接器、EPT工业控制及通讯连接器
2141|0
 楼主| hichen888 发表于 2012-8-1 11:43 | 显示全部楼层 |阅读模式
ERNI ERmet连接器、EPT工业控制及通讯连接器、3M MDR连接器、XMULTIPLE网络连接器、TE/AMP连接器、HRS连接器、WINCHESTER连接器、FOXCONN主机板连接器
Micro-Fit 3.0
3.0mm pitch wire to wire and wire to board connector
The Micro-Fit 3.0 is a unique interconnect system designed to meet the need for a high contact density signal or power connector
and incorporates many of the features previously found on larger power connectors. These 3.00mm (.118") pitch connectors are
the perfect choice when you need compact connectors that carry up to 5 amperes of current. Micro-Fit products are available in
circuit sizes 2 to 24 for single and dual row, wire-to-board and wire-to-wire applications. The product family has over 500 part
numbers, with many retention choices including fitting nails, solderable clips, and offset terminal retention.
Micro-Fit 3.0 Overmolded Cable Assemblies are available in multiple circuit sizes and cable lengths, featuring a rugged strain relief
for signal and power applications.
Specifications:
Current rating:5A AC,DC
Voltage rating:250V AC,DC
Temperature range:-25°C~+85°C
Contact resistance:10Mohm Max.
Insulation resistance:1000Mohm Min.
Withstanding voltage:1500V AC/Minute
3961
3.96mm pitch wire to board connector
With a high current carrying capacity, the VH connector can be used with a wide variety of signal, power supply, and output circuits.
Compact connector (with a mounting height of 16.5mm) with a large capacity (7A).
The housing has a lock mechanism.
Product Profile Wire to Board Crimp style Connectors
Disconnectable type,Crimp style, Compact type, With locking device
Feature With secure locking device
Specifications:
C4201
4.2mm pitch wire to wire and wire to board connector
The Mini-Fit Jr. Series is designed for high current/high density applications which require the design flexibility of wire- to-wire and wire-to-board configurations in the interconnection system. The Mini-Fit Jr. is appropriate for both power and signal applications as it can carry currents of up to 9.0A per circuit and has a 10m ohm contact resistance.The Mini-Fit product family accepts the same terminals and application tooling, further reducing your design and qualification effort.
Specifications:
Current rating:9A AC,DCVoltage rating:600V AC,DC,Temperature range:-25°C~+85°C,Contact resistance:10Mohm Max.Insulation esistance:1000Mohm Min.Withstanding voltage:1500V AC/Minute
2.1Univeal MATE-N-LOCK
6.35mm pitch wire to wire and wire to board connector
Pins and sockets can be intermixed in the same housing
?? Positive polarization
?? Rear cavity identification?? Positive locking housings?? Insulation capability to .200 [5.08] diameter?? Removable, crimp snap-in contacts?? Low contact mating force
?? Contacts accept 30-10 AWG [.05-5.0 mm2] wire sizes?? Dual locking lances provide optimum contact stability?? Panel mount or free hanging?? Mate with Universal MATE-N-LOK II Housings?? Harness to PC Board capability using pin or socket headers
?? Pin and socket headers are available in both vertical and right angle styleSpecifications:
Current rating:15A AC,DCVoltage rating:600V AC,DCemperature range:-25°C~+85°C
Contact resistance:3.5Mohm Max.Insulation resistance:1000Mohm Min.
Withstanding voltage:5000V AC/MinuteDisconncttable Connctors
2.54mm and 3.96mm IDC Connector,This 2.54 / 3.96mm pitch insulation displacementconnector is used with printed circuitboards. Since the connector
canaccommodate 18 AWG wires and has alarge pitch, it is ideal for connecting powersupply circuits.,Specifications,Current rating:7A AC, DC (AWG#18)
Voltage rating:250V AC, DC,Temperature range:-25°C to +85°C(including temperature rise in applying electrical current),Contact resistance:Initial value/10m Ωmax. After environmental testing/20 mΩmax.,Insulation resistance:1,000M Ωmin.
Withstanding voltage:1,500V AC/minute?? Applicable wire: AWG #26, #24, #22, #20, #18?? Applicable PC board thickness:0.8 to 1.6mm?? RoHS compliant products are published.PIN Header
?? Can be used for board-to-cable or board-to-board applications in combination with female connectors?? Can be used as a terminal board for switching between circuits on a PCB?? The number of contacts are selectable as required.
?? Pin is selectable to correspond to a mating female connector, or for other particular use.
?? Two types of contact plating, gold plate and tin copper plate are available, which are selectable depending on usage.?? Two colors, black and blue, are available for molded insulators.?? Extracting a pin to prevent misinsertion is possible.
?? Available in two types, top entry type and side entry type
?? Pitch 0.8/1.0 / 1.27 / 2.0 / 2.54 Female pinheader
?? Available number of circuits 2-40 position
?? Single row&double rows?? DIP SMD R/A and custermer type,PIN Female Header  ,The 2.54Pin female header can be used to connect any 2.54mm receptacles to PC boards. They can also be used to directly,connect PC boards.
?? Available in two types, top entry type and side entry type?? Pitch 0.8/1.0 / 1.27 / 2.0 / 2.54 Female pinheader?? Available number of circuits 2-40 position
MDR Recetable
Mini D Ribbon (MDR) Connectors.050 Boardmount Thru--Hole Vertical ReceptacleShieldedWiper-on-wiper contact for reliable repetitive plugging
Rugged die cast metal case construction,Screw lockdown for reliable PCB retention
Interface latch design for connection stability,IEEE 1284C Interface as a 36 contact connector,tacts: 14, 20, 26, 36, 40, 50, 68, 80 and 100
MDR Plug
Mini D Ribbon (MDR) Connectors.050 IDC Wiremount Plug Shielded
Wiper--on--wiper contact for reliable repetitive pluggingMDR digital LCD interface as a 20 or 26 contact connector
Accepts a wide variety of cable constructions including flat, round, twisted pair and twinax cables
Accepts a wide variety of shielded junction shells
Contacts: 14, 20, 26, 36, 40, 50, 68, 80 and 100
EMI shielded junction shell in either plastic or overmolded construction.
Electrical:
Voltage Rating: 30 V
Current Rating: 1 A
Insulation Resistance: > 1 × 108Ω at @100 Vdc
Withstanding Voltage: 350 Vrms for 1 minute
Individually Shielded Twisted Pairs
Characteristic Impedance: 100 ± 10Ω
Conductor Size: 28 AWG Stranded
Propogation Velocity: 1.25 ns/ft [4.1 ns/m ]
Skew (within pair): 50 ps/meter maximum
Skew (channel skew per chipset): 50 ps/meter maximum
Environmental:
Temperature Rating: --20°C to +75°C
Mini Cameralink Cable
Shrunk Delta Ribbon (SDR) Cable Assemblies, .80 mm,Mini Camera Link? Series 1MG, 1MF, 1SF
? Supplied as a Complete Assembly Only
? Supports New AIA
Industrial Camera Link? Standard for Mini C/L Camera to C/L Frame Grabber Applications
? 11 Shielded Twisted Twinax Pairs with Four Drain Wires
? Double Overall Shield with Foil and Outer Braid EMI Shielded Cable Assembly
? Straight and Right Angle Configurations Available
? SDR-to-SDR and MDR to-SDR Options Available
? Mates with 3M SDR and MDR Boardmount Products
Current Rating: 0.5 A
Temperature Rating: 0°C to 70°C
CPCI Power Connector
Compact Power Connectors are designed for use as a plug-in power interface in a wide variety of platforms. The PCIH series in the 47 contact variant was developed specifically for use with CompactPCI? 3U and 6U in-rack modular power supplies as detailed in the PICMG? 2.11 Power Interface Specification.
Features
Single package mixed density. Size 20 and 22 signal contacts, size 16 power contacts
Options for AC input, DC output, and signal in a single connector
"Touch safe" recessed female contacts
Current ratings to 40 amperes per contact
P47 is compliant to PICMG 2.11 Power Connector Interface specification
Multiple keying options
Package height is only 12.54 mm. Five different lengths available
Large Surface Area (LSA) contact system. Low contact resistance saves energy
Sequential mating options
Blind mating and panel mount
Solder PCB mount, crimp and press-fit terminations. Coplanar mounting options
Automatic crimping equipment
常用型号:PCIH47M400A1 PCIH47F300A1 PCIH47RM400A1 PICH47RF300A1 PCIC16W7M400A1
PCIC16W7F300A1
Technical data,EURO DIN41612 B,C,Q,R Type F48 Type H15 Type G Type ,
Housing PBT&30% Class Fiber(UL 94V-0) ,Contact Male:Brass,Female:Phosphor Bronze Phosphor Bronze Male:Brass,Female:Phosphor Bronze ,Operating Temp -55°C105°C ,Contact Resistance 30m(ohm) max. at DC 500V 8m(ohm)max.at DC100mA
15M(ohm) ,
Insulator Resistance 1000m(ohm) min at DC 500V 10(12次方)ohm ,Current Rating 2 AMP 5.6AMP 15AMP 6AMP ,Withstanding Voltage AC1000V for 1 minute AC3100V for 1 AC1550V for 1 ,Insertion Force 96pin max.90N,64pin max.60N,48pin max.45N,32pin max.30N,30pin max.28N,20pin max.18N  ,75N max  ,90N max ,Withdrawal Force 0.15N min.per individual contact 0.2N/pin min 0.15N/pin min,USB Connctor,USB 3.0 A Type,USB3.0A Type,SIM Card SKT,SFP SKT   SFP Cage SD SKT,SATA,SAS 4X Cable(SFF8087),SAS,PMC Jack,CMCIA SKT,PC104 PLUS,PC104,P1.27 PCI,P1.0 PCI-E,Modular Jack,Mininature Cable,MininatureMini SAS Cable(SFF8470),Mini SAS Cable(SFF8088),Mini SAS 36P Internal,Micro SD(TF),HDMI,FPC Connector,FFC,ETX Jack,DIN41612混装端子,传统牛角
各种连接器平价供应。
获得更多资讯,索取更多资料
北京海辰博创科技有限公司
010-60606267  13718719010  翁sir
010-62712788
www.hichen-tech.com
info@Hichen-tech.com
