PCB
5700|4
 楼主| 18014013 发表于 2012-8-1 13:17 | 显示全部楼层 |阅读模式
今天将LOGIC转化为layout出现了下面的错误,我看了一下,是地和电源用了错误的网络名,最后那个错误是子网用了不存在的分页索引。哪位大神帮忙看下,该怎么修改啊????
PCB Net List Errors Report - final.sch - Wed Aug 01 12:59:05 2012
Design to Library Part Consistency Check
No Library consistency checking errors.
Single/Zero Pin Net Warnings
No single or zero pin nets.
Schematic Connectivity Errors
Power or Ground Symbols used with wrong Net Name
AVCC-5
Sheet 1      X8900  Y10700 - Power  Symbol used for net: +5V
Sheet 1      X20500 Y11200 - Power  Symbol used for net: +5V
AVCC5
Sheet 1      X6800  Y13600 - Power  Symbol used for net: +5V
Sheet 1      X9100  Y10700 - Power  Symbol used for net: +5V
Sheet 1      X12000 Y10300 - Power  Symbol used for net: +5V
Sheet 1      X12600 Y11800 - Power  Symbol used for net: +5V
Sheet 1      X19554 Y11852 - Power  Symbol used for net: +5V
Sheet 1      X11500 Y15300 - Power  Symbol used for net: +5V
Sheet 1      X7500  Y12480 - Power  Symbol used for net: +5V
DGND
Sheet 1      X5200  Y9000  - Ground Symbol used for net: GND
Sheet 1      X15434 Y6516  - Ground Symbol used for net: GND
Sheet 1      X15034 Y3896  - Ground Symbol used for net: GND
Sheet 1      X15534 Y3896  - Ground Symbol used for net: GND
Sheet 1      X19634 Y6496  - Ground Symbol used for net: GND
Sheet 1      X19634 Y6096  - Ground Symbol used for net: GND
Sheet 1      X13864 Y5176  - Ground Symbol used for net: GND
Sheet 1      X4200  Y7300  - Ground Symbol used for net: GND
Sheet 1      X8900  Y4200  - Ground Symbol used for net: GND
Sheet 1      X12000 Y9600  - Ground Symbol used for net: GND
Sheet 1      X15672 Y9132  - Ground Symbol used for net: GND
Sheet 1      X13600 Y9300  - Ground Symbol used for net: GND
Sheet 1      X18030 Y11100 - Ground Symbol used for net: GND
Sheet 1      X19496 Y11246 - Ground Symbol used for net: GND
Sheet 1      X19700 Y9800  - Ground Symbol used for net: GND
Sheet 1      X16300 Y13300 - Ground Symbol used for net: GND
VCC3.3
Sheet 1      X2700  Y13600 - Power  Symbol used for net: +5V
Sheet 1      X3100  Y8900  - Power  Symbol used for net: +5V
Sheet 1      X18074 Y6656  - Power  Symbol used for net: +5V
Sheet 1      X3500  Y6700  - Power  Symbol used for net: +5V
Sheet 1      X2300  Y6700  - Power  Symbol used for net: +5V
Sheet 1      X1200  Y3500  - Power  Symbol used for net: +5V
Sheet 1      X8300  Y2100  - Power  Symbol used for net: +5V
Sheet 1      X10600 Y5300  - Power  Symbol used for net: +5V
Sheet 1      X9400  Y3300  - Power  Symbol used for net: +5V
Sheet 1      X16604 Y10648 - Power  Symbol used for net: +5V
Sheet 1      X1600  Y11600 - Power  Symbol used for net: +5V
Subnets with Missing Off-Page Reference
VCC3.3
Sheet 1      X3900  Y10900 - Pin: U2.5
 楼主| 18014013 发表于 2012-8-2 12:39 | 显示全部楼层
 楼主| 18014013 发表于 2012-8-2 15:19 | 显示全部楼层
不能沉啊,哪位仁兄帮帮忙啊。
无视提示的错误转化以后还有这个txt文档,怎么解决啊??
** ECO In Report **
Thu Aug 02 15:19:14 2012
Input  File : C:\PADS Projects\eco2pcb.eco
Current Job : Untitled
No errors found
Attribute Dictionary was modified during import operations.?The following
attributes were added to the Attribute Dictionary as non-ECO Registered:
VCC12
VCC3
VCC5
VCC_12
+5V
VCC3.3
Rules.Routing.RestrictedVias.00000
GND
redworlf 发表于 2012-9-28 10:40 | 显示全部楼层
关于这个问题:
我也遇到了,但是莫名其妙的好了,你看我的截图就知道了
