avr studio4.12版里加上了gcc的接口,我想用它直接编译.s文件,但编译后出现如下提示: Loaded plugin AVR GCC Loaded partfile: C:Program FilesAtmelAVR ToolsPartDescriptionFilesATmega8.xml gcc plug-in: Created and added E: empavrEx1Ex1.s to the project gcc plug-in: Output directory E: empavrEx1default does not exist gcc plug-in: Created directory E: empavrEx1default gcc plug-in: Error: Object file not found on expected location E: empavrEx1defaultEx1.elf gcc plug-in: Error: Object file not found on expected location E: empavrEx1defaultEx1.elf 请问高手如何解决这个问题。 |
