F2812中用C语言来实现中断的说明
2906|8
 楼主| 益友电子 发表于 2012-8-4 20:55 | 显示全部楼层 |阅读模式
1.首先在.cmd中定位系统中断表:
MEMORY
PAGE 0 :
PAGE 1 :
PIE_VECT : origin = 0x000D00, length = 0x000100
SECTIONS
PieVectTable : > PIE_VECT, PAGE = 1
2.在C中制定该中断的结构体:
#pragma DATA_SECTION(PieVectTable,"PieVectTable");
struct PIE_VECT_TABLE PieVectTable;(在DSP28_GlobalVariableDefs.C中初始化)
3.用一组常数(按照中断向量的顺序)初始化该名字为PIE_VECT_TABLE的表:
typedef interrupt void(*PINT)(void);
// Define Vector Table:
struct PIE_VECT_TABLE {
// Reset is never fetched from this table.
// It will always be fetched from 0x3FFFC0 in either
// boot ROM or XINTF Zone 7 depending on the state of
// the XMP/MC input signal. On the F2810 it is always
// fetched from boot ROM.
PINT PIE1_RESERVED;
PINT PIE2_RESERVED;
PINT PIE3_RESERVED;
PINT PIE4_RESERVED;
PINT PIE5_RESERVED;
PINT PIE6_RESERVED;
PINT PIE7_RESERVED;
PINT PIE8_RESERVED;
PINT PIE9_RESERVED;
PINT PIE10_RESERVED;
PINT PIE11_RESERVED;
PINT PIE12_RESERVED;
PINT PIE13_RESERVED;
// Non-Peripheral Interrupts:
PINT XINT13; // XINT13
PINT TINT2; // CPU-Timer2
PINT DATALOG; // Datalogging interrupt
PINT RTOSINT; // RTOS interrupt
PINT EMUINT; // Emulation interrupt
PINT XNMI; // Non-maskable interrupt
PINT ILLEGAL; // Illegal operation TRAP
PINT USER0; // User Defined trap 0
PINT USER1; // User Defined trap 1
PINT USER2; // User Defined trap 2
PINT USER3; // User Defined trap 3
PINT USER4; // User Defined trap 4
PINT USER5; // User Defined trap 5
PINT USER6; // User Defined trap 6
PINT USER7; // User Defined trap 7
PINT USER8; // User Defined trap 8
PINT USER9; // User Defined trap 9
PINT USER10; // User Defined trap 10
PINT USER11; // User Defined trap 11
// Group 1 PIE Peripheral Vectors:
PINT PDPINTA; // EV-A
PINT PDPINTB; // EV-B
PINT rsvd1_3;
PINT XINT1;
PINT XINT2;
PINT ADCINT; // ADC
PINT TINT0; // Timer 0
PINT WAKEINT; // WD
// Group 2 PIE Peripheral Vectors:
PINT CMP1INT; // EV-A
PINT CMP2INT; // EV-A
PINT CMP3INT; // EV-A
PINT T1PINT; // EV-A
PINT T1CINT; // EV-A
PINT T1UFINT; // EV-A
PINT T1OFINT; // EV-A
PINT rsvd2_8;
// Group 3 PIE Peripheral Vectors:
PINT T2PINT; // EV-A
PINT T2CINT; // EV-A
PINT T2UFINT; // EV-A
PINT T2OFINT; // EV-A
PINT CAPINT1; // EV-A
PINT CAPINT2; // EV-A
PINT CAPINT3; // EV-A
PINT rsvd3_8;
// Group 4 PIE Peripheral Vectors:
PINT CMP4INT; // EV-B
PINT CMP5INT; // EV-B
PINT CMP6INT; // EV-B
PINT T3PINT; // EV-B
PINT T3CINT; // EV-B
PINT T3UFINT; // EV-B
PINT T3OFINT; // EV-B
PINT rsvd4_8;
// Group 5 PIE Peripheral Vectors:
PINT T4PINT; // EV-B
PINT T4CINT; // EV-B
PINT T4UFINT; // EV-B
PINT T4OFINT; // EV-B
PINT CAPINT4; // EV-B
PINT CAPINT5; // EV-B
PINT CAPINT6; // EV-B
PINT rsvd5_8;
// Group 6 PIE Peripheral Vectors:
PINT SPIRXINTA; // SPI-A
PINT SPITXINTA; // SPI-A
PINT rsvd6_3;
PINT rsvd6_4;
PINT MRINTA; // McBSP-A
PINT MXINTA; // McBSP-A
PINT rsvd6_7;
PINT rsvd6_8;
// Group 7 PIE Peripheral Vectors:
PINT rsvd7_1;
PINT rsvd7_2;
PINT rsvd7_3;
PINT rsvd7_4;
PINT rsvd7_5;
PINT rsvd7_6;
PINT rsvd7_7;
PINT rsvd7_8;
// Group 8 PIE Peripheral Vectors:
PINT rsvd8_1;
PINT rsvd8_2;
PINT rsvd8_3;
PINT rsvd8_4;
PINT rsvd8_5;
PINT rsvd8_6;
PINT rsvd8_7;
PINT rsvd8_8;
// Group 9 PIE Peripheral Vectors:
PINT RXAINT; // SCI-A
PINT TXAINT; // SCI-A
PINT RXBINT; // SCI-B
PINT TXBINT; // SCI-B
PINT ECAN0INTA; // eCAN
PINT ECAN1INTA; // eCAN
PINT rsvd9_7;
PINT rsvd9_8;
// Group 10 PIE Peripheral Vectors:
PINT rsvd10_1;
PINT rsvd10_2;
PINT rsvd10_3;
PINT rsvd10_4;
PINT rsvd10_5;
PINT rsvd10_6;
PINT rsvd10_7;
PINT rsvd10_8;
// Group 11 PIE Peripheral Vectors:
PINT rsvd11_1;
PINT rsvd11_2;
PINT rsvd11_3;
PINT rsvd11_4;
PINT rsvd11_5;
PINT rsvd11_6;
PINT rsvd11_7;
PINT rsvd11_8;
// Group 12 PIE Peripheral Vectors:
PINT rsvd12_1;
PINT rsvd12_2;
PINT rsvd12_3;
PINT rsvd12_4;
PINT rsvd12_5;
PINT rsvd12_6;
PINT rsvd12_7;
PINT rsvd12_8;
然后在使我们在.cmd文件中定义的表有以上属性:
extern struct PIE_VECT_TABLE PieVectTable;(在.h文件中)
4.初始化该表(在.c文件中)使之能够为主程序所使用:
const struct PIE_VECT_TABLE PieVectTableInit = {
PIE_RESERVED, // Reserved space
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
PIE_RESERVED,
INT13_ISR, // XINT13 or CPU-Timer 1
INT14_ISR, // CPU-Timer2
DATALOG_ISR, // Datalogging interrupt
RTOSINT_ISR, // RTOS interrupt
EMUINT_ISR, // Emulation interrupt
NMI_ISR, // Non-maskable interrupt
ILLEGAL_ISR, // Illegal operation TRAP
USER0_ISR, // User Defined trap 0
USER1_ISR, // User Defined trap 1
USER2_ISR, // User Defined trap 2
USER3_ISR, // User Defined trap 3
USER4_ISR, // User Defined trap 4
USER5_ISR, // User Defined trap 5
USER6_ISR, // User Defined trap 6
USER7_ISR, // User Defined trap 7
USER8_ISR, // User Defined trap 8
USER9_ISR, // User Defined trap 9
USER10_ISR, // User Defined trap 10
USER11_ISR, // User Defined trap 11
 楼主| 益友电子 发表于 2012-8-4 20:56 | 显示全部楼层
// Group 1 PIE Vectors
PDPINTA_ISR, // EV-A
PDPINTB_ISR, // EV-B
rsvd_ISR,
XINT1_ISR,
XINT2_ISR,
ADCINT_ISR, // ADC
TINT0_ISR, // Timer 0
WAKEINT_ISR, // WD
// Group 2 PIE Vectors
CMP1INT_ISR, // EV-A
CMP2INT_ISR, // EV-A
CMP3INT_ISR, // EV-A
T1PINT_ISR, // EV-A
T1CINT_ISR, // EV-A
T1UFINT_ISR, // EV-A
T1OFINT_ISR, // EV-A
rsvd_ISR,
// Group 3 PIE Vectors
T2PINT_ISR, // EV-A
T2CINT_ISR, // EV-A
T2UFINT_ISR, // EV-A
T2OFINT_ISR, // EV-A
CAPINT1_ISR, // EV-A
CAPINT2_ISR, // EV-A
CAPINT3_ISR, // EV-A
rsvd_ISR,
// Group 4 PIE Vectors
CMP4INT_ISR, // EV-B
CMP5INT_ISR, // EV-B
CMP6INT_ISR, // EV-B
T3PINT_ISR, // EV-B
T3CINT_ISR, // EV-B
T3UFINT_ISR, // EV-B
T3OFINT_ISR, // EV-B
rsvd_ISR,
// Group 5 PIE Vectors
T4PINT_ISR, // EV-B
T4CINT_ISR, // EV-B
T4UFINT_ISR, // EV-B
T4OFINT_ISR, // EV-B
CAPINT4_ISR, // EV-B
CAPINT5_ISR, // EV-B
CAPINT6_ISR, // EV-B
rsvd_ISR,
// Group 6 PIE Vectors
SPIRXINTA_ISR, // SPI-A
SPITXINTA_ISR, // SPI-A
rsvd_ISR,
rsvd_ISR,
MRINTA_ISR, // McBSP-A
MXINTA_ISR, // McBSP-A
rsvd_ISR,
rsvd_ISR,
// Group 7 PIE Vectors
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
// Group 8 PIE Vectors
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
// Group 9 PIE Vectors
SCIRXINTA_ISR, // SCI-A
SCITXINTA_ISR, // SCI-A
SCIRXINTB_ISR, // SCI-B
SCITXINTB_ISR, // SCI-B
ECAN0INTA_ISR, // eCAN
ECAN1INTA_ISR, // eCAN
rsvd_ISR,
rsvd_ISR,
// Group 10 PIE Vectors
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
// Group 11 PIE Vectors
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
// Group 12 PIE Vectors
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
rsvd_ISR,
// InitPieVectTable:
// This function initializes the PIE vector table to a known state.
// This function must be executed after boot time.
void InitPieVectTable(void)
int16 i;
Uint32 *Source = (void *) &PieVectTableInit;
Uint32 *Dest = (void *) &PieVectTable;
EALLOW;
for(i=0; i < 128; i++)
*Dest++ = *Source++;
EDIS;
// Enable the PIE Vector Table
PieCtrl.PIECRTL.bit.ENPIE = 1;
5.中断服务程序:
让以上的数值指向你所要的服务程序,例如:
PieVectTable.TINT2 = &ISRTimer2;
那么,ISRTimer2也就成了中断服务程序,
×××切记:一定要在主程序的开始先声明该程序:
interrupt void ISRTimer2(void);
然后按照您的需要编制该程序:
CpuTimer2.InterruptCount++;
天马兰兰 发表于 2012-8-5 16:17 | 显示全部楼层
挺好的,我以前都是用的汇编,不过我觉得怎么这么复杂啊。
hawksabre 发表于 2012-8-10 19:22 | 显示全部楼层
帮你顶一个  虽然我看不懂  见笑了
srun3000 发表于 2012-11-8 22:35 | 显示全部楼层
很详细,楼主幸苦了。
