[M051] m0516串口接收中断里不能单个发送,至少发送两个!
5715|7
 楼主| abcdzhy 发表于 2012-8-9 11:13 | 显示全部楼层 |阅读模式
调试M0516的串口程序,用的串口0,发送没用中断,接收用中断,从电脑里接收一个字符再把接收到的数据发送上去,能够接收但是发送的时候至少要发两个字节才行,发一个就不行,调试了一天依然找不到原因,还请做过的大虾帮忙!
 楼主| abcdzhy 发表于 2012-8-9 11:21 | 显示全部楼层
附上程序,程序也是我根据例程改的
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      SYSCLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
/* Define functions prototype        */
int32_t main(void);
void Delay(int32_t time)
  while(time--)
void SYS_Init(void)
/* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable external 12MHz XTAL */
    SYSCLK->PWRCON |= SYSCLK_PWRCON_XTL12M_EN_Msk;
    SYSCLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    SYS_WaitingForClockReady(SYSCLK_CLKSTATUS_PLL_STB_Msk | SYSCLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to PLL */
    SYSCLK->CLKSEL0 = SYSCLK_CLKSEL0_HCLK_PLL;
    /* Enable IP clock */
    SYSCLK->APBCLK = SYSCLK_APBCLK_UART0_EN_Msk | SYSCLK_APBCLK_UART1_EN_Msk;
    /* IP clock source */
    SYSCLK->CLKSEL1 = SYSCLK_CLKSEL1_UART_PLL ;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
/* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Set P1 multi-function pins for UART1 RXD and TXD  */
    SYS->P1_MFP = SYS_MFP_P12_RXD1 | SYS_MFP_P13_TXD1;
    /* Set P0 multi-function pins for UART1 RTS and CTS */
    SYS->P0_MFP = SYS_MFP_P01_RTS1 | SYS_MFP_P00_CTS1;
    /* Lock protected registers */
    SYS_LockReg();
void UART0_Init()
/* Init UART        */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_DIV_MODE2(PLL_CLOCK,115200);
    _UART_SET_DATA_FORMAT(UART0, UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1);
/* UART Test Sample        */
/* Test Item        */
/* It sends the received data to HyperTerminal.                                                            */
/* MAIN function        */
int main(void)
     /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 for testing */
/* SAMPLE CODE        */
   // _UART_ENABLE_INT(UART0, (UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk));
    _UART_ENABLE_INT(UART0, UART_IER_RDA_IEN_Msk);
    NVIC_EnableIRQ(UART0_IRQn);
    while(1)
/* ISR to handle UART Channel 0 interrupt event                                                            */
void UART0_IRQHandler(void)
   uint8_t u8InChar=0xFF;
   uint32_t u32IntSts= UART0->ISR;
    if(u32IntSts & UART_ISR_RDA_INT_Msk)
        /* Get all the input characters */
        while(_UART_IS_RX_READY(UART0))
          while(_UART_IS_RX_FULL(UART0))
            /* Get the character from UART Buffer */
           _UART_RECEIVEBYTE(UART0,u8InChar);           /* Rx trigger level is 1 byte*/
           _UART_SENDBYTE(UART0,u8InChar);
           _UART_WAIT_TX_EMPTY(UART0);
 楼主| abcdzhy 发表于 2012-8-10 11:26 | 显示全部楼层
这个问题就没人遇到过吗?难道只有我遇到,那位大虾可以帮忙看下,自己有m0的话也可以自己试下,先谢谢了!
呆板书生 发表于 2012-8-10 20:03 | 显示全部楼层
楼主的运气真好,这样都能遇上,
我真的没有遇到过,包括051系列和nuc1xx系列,在uart0和uart1 ,我都写过不少串口程序,到目前为止还没有遇到这问题。
评分
参与人数 1威望 +1 收起 理由
296895536 + 1 求个NUC1xx串口程序。 能给我发给吗?29689.
查看全部评分
 楼主| abcdzhy 发表于 2012-8-12 07:37 | 显示全部楼层
我就是用的上面的程序,也是从例程里面改的,确实存在这样的问题,如果你发送的不是一个是不会遇到这个问题的。实际项目中应该也没人会只发送一个,所以也不容易遇到。
我是土匪 发表于 2012-8-31 23:02 | 显示全部楼层
菜鸟+新手 发表于 2012-9-14 12:11 | 显示全部楼层
你的串口调试工具配置的有问题吧?发送的时候选择十六进制的数
 楼主| abcdzhy 发表于 2012-9-27 22:05 | 显示全部楼层
串口调试工具肯定是没问题的,十六进制也是选了的。有时间了用cox调试试下
