请教下STM32F0 脉冲输出问题
2103|4
 楼主| znsword 发表于 2012-8-13 10:43 | 显示全部楼层 |阅读模式
/* 计算预分频因子 */
  PrescalerValue = (uint16_t) (SystemCoreClock  / 16000000) - 1;// 用RCC默认设置,48MHz
  /* 时基设置 */
  TIM_TimeBaseStructure.TIM_Period = 511;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* 输出比较模式设置 通道2*/
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val; // 这个值根本没有用?
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Disable);
  TIM_ARRPreloadConfig(TIM3, DISABLE);
  /* 使能TIM3计数器 */
  TIM_Cmd(TIM3, ENABLE);
  TIM_GenerateEvent(TIM3, TIM_EventSource_Update);
  /* 使能GPIOC输入时钟 */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
  /* GPIOC 配置: TIM3 CH2 (PC7) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* 连接TIM3通道与AF */
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_1);
我想用上面这段程序输出一个频率大约几百K的脉冲,但是实验的时候发现无法输出。频率大约到十几K之后,示波器上就什么都看不到了。用的是STM32F0-M51 discovery。
lvjing880907 发表于 2012-8-13 11:24 | 显示全部楼层
5509 发表于 2012-8-13 11:58 | 显示全部楼层
对的,GPIO配置错误
 楼主| znsword 发表于 2012-8-13 14:43 | 显示全部楼层
哪里配置错了?
 楼主| znsword 发表于 2012-8-13 14:51 | 显示全部楼层
晕,的确不应该加
  /* 连接TIM3通道与AF */
