求助这跳指令ADDLT PC,PC,R1;CC5.2编译不过
1739|0
scfor|  楼主 | 2012-8-24 18:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
■ A branch or any instruction that modifies the PC must either be outside an IT block or must be
the last instruction inside the IT block. These are:
– ADD PC, PC, Rm
– MOV PC, Rm
– B, BL, BX, BLX
– any LDM, LDR, or POP instruction that writes to the PC
这里提到的 IT block 是什么意思?把指令换成ADD   PC,PC,R1;倒是可以编译通过。
