我的FSMC配置在此,请大家看看有没有什么问题,谢谢
#define FSMC_Bank_NAND FSMC_Bank2_NAND
#define Bank_NAND_ADDR Bank2_NAND_ADDR
#define Bank2_NAND_ADDR ((uint32_t)0x70000000)
void FSMC_NAND_Init(void)
/*********************端口配置Nand Flash********************/
/* pinD10 为CLE输入信号, pinD12为ALE输入信号 */
/* pinD13 为WP输入信号, pinD4 为RE输入信号 */
/* pinD5 为WE输入信号, pinD6 为R/B输入信号 */
/* pinD0 pinD1 pinD14 pinD15 对应i/o */
/* pinE7 pinE8 pinE9 pinE10 */
// GPIO_InitTypeDef GPIO_InitStructure;
FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
FSMC_NAND_PCCARDTimingInitTypeDef p;
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
// RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE, ENABLE); //开GPIOD GPIOE时钟
/*-- GPIO Configuration ------------------------------------------------------*/
/* CLE, ALE, D0->D3, NOE, NWE and NCE2 NAND pin configuration */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_Init(GPIOD,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 |
GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_14 | GPIO_Pin_15 ;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
/* D4->D7 NAND pin configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
GPIO_Init(GPIOE, &GPIO_InitStructure);
p.FSMC_SetupTime = 2;//8;//0x1; //建立时间
p.FSMC_WaitSetupTime = 6;//15;//0x3; //等待时间
p.FSMC_HoldSetupTime = 4;//16;//0x2; //保持时间
p.FSMC_HiZSetupTime = 2;//0x1; //高阻建立时间
FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND; //使用FSMC BANK2
FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable; //使能FSMC的等待功能
FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b; //NAND Flash的数据宽度为8位
FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable; //使能ECC特性
FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_2048Bytes; //ECC页大2048
FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;
FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;
FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
FSMC_NANDInit(&FSMC_NANDInitStructure);
/*使能FSMC BANK2 */
FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
GPIO_ResetBits(GPIOD,GPIO_Pin_13);
GPIO_SetBits (GPIOD,GPIO_Pin_13);
