timer1的中断入口设定
2191|2
 楼主| chao11yue 发表于 2012-8-31 14:37 | 显示全部楼层 |阅读模式
本来采用的timer0,但是它的PRD貌似不能更改,所以想采用timer1,但是却进不了中断了。我的设置中断向量表的程序如下:
* Copyright (C) 2003 Texas Instruments Incorporated
* All Rights Reserved
*---------vecs_timer1.asm---------
* Assembly file to set up interrupt service table (IST)
* Global symbols defined here and exported out of this file
.global _vectors
.global _c_int00
.global _vector1
.global _vector2
.global _vector3
.global _vector4
.global _vector5
.global _vector6
.global _vector7
.global _vector8
.global _vector9
.global _vector10
.global _vector11
.global _vector12
.global _vector13
.global _vector14
.global _extint7_isr ; Hookup the c_int14 ISR in main()
* Global symbols referenced in this file but defined somewhere else.
* Remember that your interrupt service routines need to be referenced here.
.ref _c_int00
.ref _extint14_isr ; external interrupt INT 7 handler
* This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr
STW B0,*--B15
MVKL addr,B0
MVKH addr,B0
B B0
LDW *B15++,B0
NOP 2
NOP
NOP
.endm
* This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:
B B3
NOP 5
* This is the actual interrupt service table (IST). It is properly aligned and
* is located in the subsection .text:vecs. This means if you don't explicitly
* specify this section in your linker command file, it will default and link
* into the .text section. Remember to set the ISTP register to point to this
* table.
.sect ".vectors"
;.align 1024
_vectors:
_vector0: VEC_ENTRY _c_int00 ;RESET
_vector1: VEC_ENTRY _vec_dummy ;NMI
_vector2: VEC_ENTRY _vec_dummy ;RSVD
_vector3: VEC_ENTRY _vec_dummy
_vector4: VEC_ENTRY _vec_dummy
_vector5: VEC_ENTRY _vec_dummy
_vector6: VEC_ENTRY _vec_dummy
_vector7: VEC_ENTRY _vec_dummy
_vector8: VEC_ENTRY _vec_dummy
_vector9: VEC_ENTRY _vec_dummy
_vector10: VEC_ENTRY _vec_dummy
_vector11: VEC_ENTRY _vec_dummy
_vector12: VEC_ENTRY _vec_dummy
_vector13: VEC_ENTRY _vec_dummy
_vector14: VEC_ENTRY _vec_dummy
_vector15: VEC_ENTRY _extint14_isr ; Hookup the c_int14 ISR in main()
然后在主程序中设置了
IER=1; /* disable all interrupts except NMI */
ICR=0xffff; /* clear all pending interrupts */
ISTP = 0x10800400;
INTC_EVTCLR0 = 0xFFFFFFFF;
INTC_EVTCLR1 = 0xFFFFFFFF;
INTC_EVTCLR2 = 0xFFFFFFFF;
INTC_EVTCLR3 = 0xFFFFFFFF;
INTC_EVTMASK3 = 0xFFFFFFFF;
INTC_EVTMASK2 = 0xFFFFFFFF;
INTC_EVTMASK1 = 0xFFFFFFFF;
INTC_EVTMASK0 = 0xFFFFFFEF;
INTC_INTMUX3 = 0x00040000;
IER |= 0x00008002;
并编写了中断程序interrupt void extint14_isr(void)
现在进不去中断程序,请各位大神赐教啊!!
我用的DM6437
五谷道场 发表于 2012-8-31 14:42 | 显示全部楼层
没进中断处理的原因很多:
1、没有使能
2、定时器1的中断号与中断处理程序不匹配。
3、mask位是否设置。
