请问NUC100VE3AN怎么IS61C6416AL 读写数据
3010|1
 楼主| qtmm 发表于 2012-9-13 16:39 | 显示全部楼层 |阅读模式
/*下面的程序为什么读出来是0  究竟是什么问题呢 麻烦各位指点一下 谢谢了*/
//  mtcGPIO_Open_PMD 的函数
int32_t mtcGPIO_Open_PMD(E_DRVGPIO_PORT port, int32_t i32Bit, E_DRVGPIO_IO mode)
    volatile uint32_t u32Reg;
    u32Reg = (uint32_t)&GPIOA->PMD + (port*PORT_OFFSET);
  if ((mode == E_IO_INPUT) || (mode == E_IO_OUTPUT) || (mode == E_IO_OPENDRAIN) || (mode == E_IO_QUASI))
        outpw(u32Reg, i32Bit);
return E_SUCCESS;
#include <stdio.h>
#include "NUC1xx.h"
#include "DrvGPIO.h"
#include "DrvSYS.h"
#define     WE_         0x0100  //PC8;
#define     ALE         0x0100  //PB8;
#define     RAMALL_     0x8000  //PA15;
#define     I_O         0xFFFFFFFF  //PD0_15; 双向
#define     sc          0x55555555  //全部端口设置为输出模式
#define     sr          0    //全部端口设置为输入模式
uint32_t d,dd,num;
void delay_10ms(uint32_t x)
uint32_t i,j;
for(;x>0;x--)
  for(i=20;i>0;i--)
   for(j=100;j>0;j--)  ;
void  init_ram(void)
DrvGPIO_Open(E_GPB, 8, E_IO_OUTPUT);
DrvGPIO_Open(E_GPA, 15, E_IO_OUTPUT);
DrvGPIO_Open(E_GPA, 13, E_IO_OUTPUT);
DrvGPIO_Open(E_GPA, 12, E_IO_OUTPUT);
DrvGPIO_Open(E_GPC, 8, E_IO_OUTPUT);
DrvGPIO_SetBit(E_GPA, 15);   //置位ce
// DrvGPIO_ClrBit(E_GPA, 15);
delay_10ms(1);
DrvGPIO_SetBit(E_GPA, 14);   //置位OE
delay_10ms(1);
DrvGPIO_SetBit(E_GPA, 13);   //置位UB
delay_10ms(1);
DrvGPIO_SetBit(E_GPA, 12);   //置位LB
delay_10ms(1);
DrvGPIO_SetBit(E_GPC, 8);   //置位WE
delay_10ms(1);
DrvGPIO_ClrBit(E_GPB, 8);
delay_10ms(1);
void  writeRamWords(void)
uint32_t c=0x33;
mtcGPIO_Open_PMD(E_GPD,sc, E_IO_INPUT);    //输出模式
delay_10ms(1);
DrvGPIO_SetPortBits(E_GPD,0x11);      ///写地址
delay_10ms(50);
DrvGPIO_ClrBit(E_GPB, 8);       ///地址锁存
delay_10ms(50);
DrvGPIO_SetBit(E_GPB, 8);       ///地址解锁
delay_10ms(50);
DrvGPIO_SetBit(E_GPA, 14);      //禁止OE
delay_10ms(50);
   DrvGPIO_ClrBit(E_GPA, 15);      ///使能CE
delay_10ms(1);
DrvGPIO_ClrBit(E_GPC, 8);    ///使能WE
delay_10ms(1);
DrvGPIO_ClrBit(E_GPA, 13);       ///使能UB
delay_10ms(1);
DrvGPIO_ClrBit(E_GPA, 12);     ///使能LB
delay_10ms(1);
// DrvGPIO_SetBit(E_GPA, 14);      //禁止OE
delay_10ms(150);
DrvGPIO_SetPortBits(E_GPD,c);  ///写入数据
num=c;
delay_10ms(150);
// DrvGPIO_SetBit(E_GPA, 15);
   delay_10ms(1);
DrvGPIO_SetBit(E_GPC, 8);   ///置位WE
delay_10ms(1);
delay_10ms(1);
delay_10ms(1);
   DrvGPIO_SetBit(E_GPA, 15);      ///静止CE
void  ReadRamWords(void)
mtcGPIO_Open_PMD(E_GPD,sc, E_IO_OUTPUT);        ///设置模式
delay_10ms(1);
delay_10ms(50);
DrvGPIO_ClrBit(E_GPB,8);    ///地址锁存
delay_10ms(50);
DrvGPIO_SetBit(E_GPB,8);    ///地址解锁
delay_10ms(50);
delay_10ms(50);
mtcGPIO_Open_PMD(E_GPD,sr, E_IO_OUTPUT);        ///设置模式
delay_10ms(1);
DrvGPIO_SetBit(E_GPC, 8);   ///pc.8=1 WE
delay_10ms(1);
delay_10ms(1);
delay_10ms(1);
delay_10ms(1);
  DrvGPIO_ClrBit(E_GPA, 14);    //使能OE
delay_10ms(150);
d=(DrvGPIO_GetPortBits(E_GPD));    //.读取数据
delay_10ms(150);
DrvGPIO_SetBit(E_GPA, 14);   //置位oe
delay_10ms(1);
delay_10ms(1);
delay_10ms(1);
DrvGPIO_SetBit(E_GPA, 15);    ///置位CE
delay_10ms(150);
dd=(DrvGPIO_GetPortBits(E_GPD));    //.读取数据
int main(void)
init_ram();
delay_10ms(1);                      //初始化
DrvGPIO_Open(E_GPC, 10, E_IO_OUTPUT);    //设置c端口第10脚为输出模式
writeRamWords();         //向IS61c写入数据
delay_10ms(250);
ReadRamWords();            //从IS61c 读出数据
if(num == 0)   DrvGPIO_SetBit(E_GPC, 10);
if(d != 0)
    DrvGPIO_SetBit(E_GPC, 10);       //读出的数据不等于0
else
  DrvGPIO_ClrBit(E_GPC, 10);       //读出的数据等于0
    while(1);
wangch_sh 发表于 2013-6-26 16:27 | 显示全部楼层
貌似模拟时序。
