帮忙看看2407用 ALTERA CPLD扩展IO 的问题
3877|3
 楼主| tms320f240 发表于 2007-9-2 12:02 | 显示全部楼层 |阅读模式
如附图所示:<br />D[7..0]为数据总线低8位。<br />通过ALTERA自带的373扩展输出IO,A2、A1、A0译码后<br />提供片选,现在的问题是编译后没有错误,但有好多报警:<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|67&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|68&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|69&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|70&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|71&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|72&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|73&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst17|74&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|67&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|68&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|69&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|70&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|71&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|72&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|73&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst18|74&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|67&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|68&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|69&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|70&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|71&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|72&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|73&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst19|74&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst20|67&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst20|68&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst20|69&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst20|70&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst20|71&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br />Warning:&nbsp;Removed&nbsp;always-enabled&nbsp;tri-state&nbsp;buffer&nbsp;74373:inst20|72&nbsp;feeding&nbsp;logic,&nbsp;open-drain&nbsp;buffer&nbsp;or&nbsp;output&nbsp;pin<br /><br /><br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D0&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D1&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D2&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D3&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D4&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D5&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D6&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br />&nbsp;&nbsp;&nbsp;&nbsp;Warning:&nbsp;Node&nbsp;&quot;D7&quot;&nbsp;is&nbsp;assigned&nbsp;to&nbsp;location&nbsp;or&nbsp;region,&nbsp;but&nbsp;does&nbsp;not&nbsp;exist&nbsp;in&nbsp;design<br /><br /><br />哪位帮忙看看是什么原因啊?<br /><br /> 相关链接:<a href='https://bbs.21ic.com/upfiles/img/20079/20079211595238.pdf'>https://bbs.21ic.com/upfiles/img/20079/20079211595238.pdf</a>
tjsheep 发表于 2007-9-3 19:32 | 显示全部楼层
d0到d7没有用到,373的使能被取消了,因为常使能
 楼主| tms320f240 发表于 2007-9-4 20:18 | 显示全部楼层
呵呵,那样设计IO扩展有问题吗?有没有更好的扩展IO方法?
arthur02 发表于 2010-6-11 11:10 | 显示全部楼层
附图 看不到啊
