原代码:
WDTCTL = WDTPW+WDTHOLD; // Stop WDT
PMAPPWD = 0x02D52; // Enable Write-access to modify port mapping registers
P4MAP7 = PM_MCLK;
PMAPPWD = 0;
UCSCTL3 |= SELREF_2; // Set DCO FLL reference = REFO
UCSCTL4 |= SELA_2; // Set ACLK = REFO *********
// Increase Vcore setting to level1 to support fsystem=12MHz
// NOTE: Change core voltage one level at a time..
//SetVcoreUp (0x01);
// Initialize DCO to 12MHz
__bis_SR_register(SCG0); // Disable the FLL control loop
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; // Select DCO range 24MHz operation
UCSCTL2 = FLLD_1 + 374; // Set DCO Multiplier for 12MHz
// (N + 1) * FLLRef = Fdco
// (374 + 1) * 32768 = 12MHz
// Set FLL Div = fDCOCLK/2
__bic_SR_register(SCG0); // Enable the FLL control loop
// Worst-case settling time for the DCO when the DCO range bits have been
// changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
// UG for optimization.
// 32 x 32 x 12 MHz / 32,768 Hz = 375000 = MCLK cycles for DCO to settle
__delay_cycles(375000);
// Loop until XT1,XT2 & DCO fault flag is cleared
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG);
// Clear XT2,XT1,DCO fault flags
SFRIFG1 &= ~OFIFG; // Clear fault flags
}while (SFRIFG1&OFIFG); // Test oscillator fault flag
该代码调试是可以通过的,
但是,上述代码中其他寄存器的配置都不变
我仅改动 UCSCTL4 为
UCSCTL4 |= SELA_2+SELM0+SELM1+SELS0+SELS1; // Set ACLK = REFO MCLK =SCLK=DCOCLK =12MHz
就通过不了,一直在
do
循环中出不来,想问下大虾门是何原因? |
