| 下面是DNW输出的信息,从flash中启动后输出最下面的四行,不知怎么回事,请高手指点。板子是128MB内存,256MB nand flash,谢谢了! Welcome! This tool just for TE/OK6410
 +OALArgsInit()
 SocID:0x36410101
 Arguments area is initialized
 -OALArgsInit()
 INFO: (unsigned)C_IsrHandler : 0x80066598
 INFO: (unsigned)ASM_IsrHandler : 0x80069A70
 INFO: (unsigned)pISR : 0xEA01A694
 HSMMC init
 [HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
 [HSMMC0] Setting registers for the GPIO.
 [HSMMC1] Setting registers for the EPLL : HSMMCCon.
 #### this SD card is made on SPEC 2.0
 This SD card is made on SPEC 2.0
 This SD card is High Capacity
 CardSize: 15523840 sector
 [HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
 BP_Init
 [FMD] ++FMD_Init() ****
 [FMD:INF] FMD_Init() : Read ID = 0x0000ecda
 [FMD] FMD_Init() : NUM_OF_BLOCKS = 2048
 [FMD] FMD_Init() : PAGES_PER_BLOCK = 64
 [FMD] FMD_Init() : SECTORS_PER_PAGE = 4
 [FMD] --FMD_Init()
 [FMD] FMD_GetInfo() : NUMBLOCKS = 2048(0x800), SECTORSPERBLOCK = 64(0x40), BYTESPERSECTOR = 2048(0x800)
 wNUM_BLOCKS : 2048(0x800)
 [Eboot] ++InitializeDisplay()
 [Eboot] --InitializeDisplay()
 Press [ENTER] to launch image stored on boot media, or [SPACE] to enter boot monitor.
 Initiating image launch in 0 seconds.
 Starting auto-download ...
 Erase  the block '0..3'
 System ready!
 Preparing for download...
 IsCardInserted
 f_mount return = 0x0
 FileInfo.fsize = 0x2000
 g_pDownPt = 0xA300211B
 BL_IMAGE_TYPE_MANIFEST
 BL_IMAGE_TYPE_UNKNOWN
 Download BIN file information:
 [0]: Base Address=0x0  Length=0x2000
 Stepldr image
 ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
 Completed file(s):
 [0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
 dwImageLength = 0x2000
 dwNumBlocks = 0x1
 dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x40) = 0x0
 dwBytesPerBlock : 131072
 INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
 IsCardInserted
 FileInfo.fsize = 0x1C3DB
 g_pDownPt = 0xA301C3DB
 BL_IMAGE_TYPE_BIN
 [0]: Base Address=0x80030000  Length=0x1db3c
 Eboot image
 rom_offset=0x0.
 ImageStart = 0x80030000, ImageLength = 0x1DB3C, LaunchAddr = 0x80041D3C
 Completed file(s):
 [0]: Address=0x80030000  Length=0x1DB3C  Name="" Target=RAM
 ROMHDR at Address 80030044h
 dwImageLength = 0x1db3c
 dwNumBlocks = 0x1
 dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x40) = 0x80
 TOC {
 dwSignature: 0x434F544E
 BootCfg {
 ConfigFlags: 0x20830
 BootDelay: 0x2
 ImageIndex: 1
 IP: 0.0.0.0
 MAC Address: 00:00:00:00:00:00
 Port: 0.0.0.0
 SubnetMask: 255.255.255.0
 ID[0] {
 dwVersion: 0x20004
 dwSignature: 0x45424F54
 String: 'eboot.nb0'
 dwImageType: 0x2
 dwTtlSectors: 0x3C
 dwLoadAddress: 0x80030000
 dwJumpAddress: 0x80041D3C
 dwStoreOffset: 0x0
 sgList[0].dwSector: 0x80
 sgList[0].dwLength: 0x3C
 ID[1] {
 dwVersion: 0x1
 dwSignature: 0x43465348
 String: ''
 dwImageType: 0x2
 dwTtlSectors: 0x4C08
 dwLoadAddress: 0x80100000
 dwJumpAddress: 0x80107734
 dwStoreOffset: 0x0
 sgList[0].dwSector: 0x380
 sgList[0].dwLength: 0x4C08
 chainInfo.dwLoadAddress: 0X00000000
 chainInfo.dwFlashAddress: 0X00000000
 chainInfo.dwLength: 0X00000000
 INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
 Reserving Blocks [0x0 - 0x5] ...
 ...reserve complete.
 Enter LowLevelFormat [0x6, 0x7ff].
 Erasing flash block(s) [0x6, 0x7ff] (please wait): EraseBlocks: found a bad block (0x7) - skipping...
 EraseBlocks: found a bad block (0x5c6) - skipping...
 EraseBlocks: found a bad block (0x7c8) - skipping...
 Done.
 WriteMBR: MBR block = 0x6.
 Done.
 BinFS format done.
 IsCardInserted
 FileInfo.fsize = 0x2565217
 g_pDownPt = 0xA5565217
 BL_IMAGE_TYPE_BIN
 [0]: Base Address=0x80100000  Length=0x2603ba8
 RAM image
 rom_offset=0x0.
 ImageStart = 0x80100000, ImageLength = 0x2603BA8, LaunchAddr = 0x80107734
 Completed file(s):
 [0]: Address=0x80100000  Length=0x2603BA8  Name="" Target=RAM
 ROMHDR at Address 80100044h
 +WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80100000, ImageLength: 0x2603ba8, LaunchAddr:0x80107734
 INFO: OEMLaunch: Found chain extenstion: '' @ 0x80100000
 Writing single region/multi-region update, dwBINFSPartLength: 39861160
 IsValidMBR: MBR sector = 0x180 (valid MBR)
 OpenPartition: Partition Exists=0x0 for part 0x21.
 CreatePartition: Enter CreatePartition for 0x21.
 LastLogSector: Last log sector is: 0x1fdbf.
 CreatePartition: Start = 0x1c0, Num = 0x4c40.
 Log2Phys: Logical 0x1c0 -> Physical 0x380
 BP_SetDataPointer at 0x0
 WriteData: Start = 0x0, Length = 0x2603ba8.
 Writing Image ......
 ################################################################################################################################################################################################################################################################################################################Updated TOC!
 OpenPartition: Partition Exists=0x0 for part 0xb.
 CreatePartition: Enter CreatePartition for 0xb.
 FindFreeSector: FreeSector is: 0x4e00 after processing part 0x21.
 CreatePartition: Num sectors set to 0x1ae80 to allow for compaction blocks.
 CreatePartition: Start = 0x4e00, Num = 0x1ae80.
 TOC {
 BootCfg {
 BootDelay: 0x2
 ImageIndex: 1
 IP: 0.0.0.0
 Port: 0.0.0.0
 ID[0] {
 dwVersion: 0x20004
 String: 'eboot.nb0'
 dwImageType: 0x2
 dwTtlSectors: 0x3C
 dwStoreOffset: 0x0
 ID[1] {
 dwVersion: 0x1
 String: ''
 dwImageType: 0x2
 dwStoreOffset: 0x0
 waitforconnect
 INFO: using TOC[1] dwJumpAddress: 0x80107734
 Success!
 SpinForever...
 WinCE 6.0 Steploader for SMDK6410
 M ECC Err
 M ECC Err
 ECC Error.
