请教大家,TI的AFE5801的手册中的问题!!!
2271|1
 楼主| nuaakhai 发表于 2012-10-8 09:06 | 显示全部楼层 |阅读模式
AFE5801中ADC的参考电压是多少?手册中好像说的不清楚,ADC转换的基准电压是多少呢?
 楼主| nuaakhai 发表于 2012-10-8 09:15 | 显示全部楼层
The internal reference mode (default) uses approximately 3mW more power on AVDD (which is already included in all the specification tables). The AFE5801 can operate in external reference mode by programming EXTERNAL_REFERENCE to 1. In this mode, the VREF_IN pin should be driven with 1.4V.
这句话是说明内部参考电压模式下,参考电压就是AVDD吗?可是芯片有AVDD3(3.3V)和AVDD18(1.8V)两种啊。http://www.ti.com/lit/ds/symlink/afe5801.pdf
