Verilog实现parallel到parallel数据的转换
1844|0
 楼主| lxAPP 发表于 2012-10-8 22:18 | 显示全部楼层 |阅读模式
paralle 到parallel数据的转换也并没有是以意义,这里只是顺带说明,代码如下:
module p2p(clk,rstn,pi,po);
  input clk;
  input rstn;
  input[4:0] pi;
  output[4:0] po;
  reg[8:0]  r ;
  always@(posedge clk or negedge rstn)
     if(!rstn)
        r  <= 8'h0;
      else
        r   <= pi;
  assign  po  = r[4:0];
endmodule
以下内容为testbench:
module  p2p_tb;
  reg clk;
  reg rstn;
  reg[4:0] pi;
  wire[4:0] po;
  p2p ut(clk,rstn,pi,po);
  initial begin
     rstn  = 0 ;
     #5;
     rstn  = 1;
  end
  initial clk = 0;
  always #10 clk = ~clk;
  initial begin
     pi  = 9'h0;
     #20;
     pi  = 9'h10;
     #20;
     pi  = 9'h15;
     #20;
     pi  = 9'h9;
     #300;
     $finish;
   end
endmodule
