Verilog讨论组精彩内容摘录
1409|0
星星之火红|  楼主 | 2012-10-17 12:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问题:  我遇到了一个问题,希望能得到帮助。
  我在用FPGA(ALTERA 10K30)做仿真实验时,内部的计数器总是计数不正常,但是我在微机中用ModelSim仿真的结果是正确的,所以逻辑应该没有问题,问题出在FPGA,请教各位,我该如何解决这个问题。谢谢!
  I met a question,hope someone could do me a favor.
  when I used FPGA do simulating experiment, i found the inner counter worked abnormally.but if i use ModelSim do such a experiment,everything is ok.so i confirm the problem should be due to FPGA.
  who can tell me how to deal with this problem? thanks a lot!
