关于DSP281X变量地址定位问题
3692|5
 楼主| hotpower 发表于 2008-4-17 01:37 | 显示全部楼层 |阅读模式
DSP, TI, LCD, CD, LED
在结合硬件的编程中,有些变量需要特定地址.<br /><br />一般可以采用指针变量.<br />例如:<br />unsigned&nbsp;int&nbsp;*LedReg&nbsp;&nbsp;&nbsp;=&nbsp;(unsigned&nbsp;int&nbsp;*)0x5f00;//发光二极管地址<br />*LedReg&nbsp;=&nbsp;0xFF;<br /><br />但有些时候感觉不是太好时,可以像Keil那样<br /><br />unsigned&nbsp;int&nbsp;LedReg&nbsp;at&nbsp;0x5f00;//发光二极管地址<br />LedReg&nbsp;=&nbsp;0xFF;<br /><br />这样看着&quot;比较顺眼&quot;~~~<br />但在TIDSP的CCS环境下,不能采用at或__at等来定位地址.<br />不过CCS也提供了类似的手段,不过有些&quot;麻烦&quot;.<br /><br />具体实现:<br /><br />1.在CMD文件中<br /><br />MEMORY<br />{<br />&nbsp;PAGE&nbsp;0:&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;Program&nbsp;Memory&nbsp;*/<br /><br />&nbsp;PAGE&nbsp;1:&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;Data&nbsp;Memory&nbsp;*/<br />&nbsp;<br />&nbsp;&nbsp;&nbsp;LED_REG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005f00,&nbsp;length&nbsp;=&nbsp;0x00001&nbsp;/*发光二极管地址*/<br />&nbsp;&nbsp;&nbsp;LCD_ComL&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005100,&nbsp;length&nbsp;=&nbsp;0x00001&nbsp;<br />&nbsp;&nbsp;&nbsp;LCD_ComH&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005200,&nbsp;length&nbsp;=&nbsp;0x00001<br />&nbsp;&nbsp;&nbsp;LCD_DatL&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005300,&nbsp;length&nbsp;=&nbsp;0x00001<br />&nbsp;&nbsp;&nbsp;LCD_DatH&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005400,&nbsp;length&nbsp;=&nbsp;0x00001<br />&nbsp;&nbsp;&nbsp;EINT_REG&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005c00,&nbsp;length&nbsp;=&nbsp;0x00001<br />&nbsp;&nbsp;&nbsp;KEY_REG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005b00,&nbsp;length&nbsp;=&nbsp;0x00001<br />&nbsp;&nbsp;&nbsp;RCLK_REG&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;origin&nbsp;=&nbsp;0x005500,&nbsp;length&nbsp;=&nbsp;0x00001&nbsp;/*数码管锁存地址*/<br />}<br /><br />&nbsp;<br />SECTIONS<br />{<br />&nbsp;&nbsp;&nbsp;LedDataRegsFile&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;LED_REG,&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;LcdComlRegsFile&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;LCD_ComL,&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;LcdComhRegsFile&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;LCD_ComH,&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;LcdDatlRegsFile&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;LCD_DatL,&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;LcdDathRegsFile&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;LCD_DatH,&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;KeyRegsFile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;KEY_REG,&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;EintRegsFile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;EINT_REG,&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;RclkRegsFile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;&gt&nbsp;RCLK_REG,&nbsp;&nbsp;&nbsp;&nbsp;PAGE&nbsp;=&nbsp;1<br />}<br /><br />2.在C/C++文件中<br /><br /><br />#ifdef&nbsp;__cplusplus&nbsp;<br />#pragma&nbsp;DATA_SECTION(&quot;LedDataRegsFile&quot;)&nbsp;/*C++语言格式*/<br />#else&nbsp;<br />#pragma&nbsp;DATA_SECTION(LedRegs,&quot;LedDataRegsFile&quot;);/*C语言格式*/<br />#endif<br />volatile&nbsp;unsigned&nbsp;int&nbsp;LedRegs;<br /><br />/*以下为C++语言格式*/<br /><br />#pragma&nbsp;DATA_SECTION(&quot;LcdComlRegsFile&quot;)&nbsp;<br />volatile&nbsp;unsigned&nbsp;int&nbsp;LcdComL;<br />#pragma&nbsp;DATA_SECTION(&quot;LcdComhRegsFile&quot;)&nbsp;<br />volatile&nbsp;unsigned&nbsp;int&nbsp;LcdComH;<br />#pragma&nbsp;DATA_SECTION(&quot;LcdDatlRegsFile&quot;)&nbsp;<br />volatile&nbsp;unsigned&nbsp;int&nbsp;LcdDatL;<br />#pragma&nbsp;DATA_SECTION(&quot;LcdDathRegsFile&quot;)&nbsp;<br />volatile&nbsp;unsigned&nbsp;int&nbsp;LcdDatH;<br /><br />#pragma&nbsp;DATA_SECTION(&quot;EintRegsFile&quot;)&nbsp;<br />volatile&nbsp;unsigned&nbsp;int&nbsp;EintRegs;<br /><br />#pragma&nbsp;DATA_SECTION(&quot;KeyRegsFile&quot;)&nbsp;<br />volatile&nbsp;unsigned&nbsp;char&nbsp;KeyRegs;<br /><br />#pragma&nbsp;DATA_SECTION(&quot;RclkRegsFile&quot;)&nbsp;<br />volatile&nbsp;bool&nbsp;SpiRclkRegs;<br /><br /><br />3.在应用程序中<br /><br />extern&nbsp;unsigned&nbsp;int&nbsp;LedRegs;<br />extern&nbsp;volatile&nbsp;unsigned&nbsp;int&nbsp;EintRegs;<br />extern&nbsp;volatile&nbsp;unsigned&nbsp;char&nbsp;KeyRegs;<br />extern&nbsp;volatile&nbsp;bool&nbsp;SpiRclkRegs;<br />//............<br />LedRegs&nbsp;=&nbsp;0xff;//这样就不需要指针变量的写法了<br />//..................<br /><br />//HotPower@126.com&nbsp;2008.4.17&nbsp;1:34<br />
zgl7903 发表于 2008-4-17 09:06 | 显示全部楼层
可以使用宏定义阿,是不是更简单些?
#define&nbsp;LedReg&nbsp;(*(unsigned&nbsp;int&nbsp;*)0x5f00)//发光二极管地址<br /><br />应用时<br />LedReg&nbsp;=&nbsp;0xFF;<br />GetLed&nbsp;=&nbsp;LedReg;
 楼主| hotpower 发表于 2008-4-17 09:14 | 显示全部楼层
哈哈~~~正在当28菜鸟~~~
俺也是喜欢宏的~~~ <br /> 相关链接:<a href='http://blog.**/hotpower/85874/message.aspx'>http://blog.**/hotpower/85874/message.aspx</a>
 楼主| hotpower 发表于 2008-4-17 12:31 | 显示全部楼层
哈哈~~~两者的差异在于能否在变量窗口中查看具体的数值~~~
#define&nbsp;LedReg&nbsp;(*((unsigned&nbsp;int&nbsp;*)0x5f00))//发光二极管地址<br /><br />
zealane 发表于 2008-4-17 15:45 | 显示全部楼层
re
unsigned&nbsp;int&nbsp;*LedReg&nbsp;&nbsp;&nbsp;=&nbsp;(unsigned&nbsp;int&nbsp;*)0x5f00;//发光二极管地址<br />*LedReg&nbsp;=&nbsp;0xFF;<br /><br />汗,我一直这么用的。<br />可能是因为用的少吧,也不觉得有什么不方便
 楼主| hotpower 发表于 2008-4-18 20:51 | 显示全部楼层
有空说说三种方法的不同和优缺点~~~
