急!!新手求教STM8捕获问题
1841|0
 楼主| velf8 发表于 2012-10-19 10:14 | 显示全部楼层 |阅读模式
我用的是STM8S105K4 用TIM2进行外部捕获脉冲个数,源代码如下:
void Clk_set(void)
CLK_ICKR |=0X1;
    CLK_CMSR=0Xe1;
    //CLK_CKDIVR=0;
CLK_CKDIVR = 0x08;//设置为2分频,16M/2=8M
CLK_PCKENR1=0xff;//e6
void TIM_init2(void)
  TIM2_CR1 = 0x04;
  TIM2_EGR = 0x00;
  TIM2_CCER1 = 0x00;
  TIM2_CCER1 = 0x00;
  TIM2_PSCR = 0x03;//fcnt=8M/(8)=1000kHz=1us
  TIM2_ARRH = 0xFF;// 自动重载寄存器ARR=0x01F4=50000
  TIM2_ARRL = 0xFF;// 每记数50000次产生一次中断,即50ms
  TIM2_CCMR2 = 0x51;
  TIM2_CCER1 = 0x20;
  TIM2_IER |= 0x05;// 允许捕获,计数器使能,开始计数
  TIM2_SR1 = 0;
  TIM2_SR2 = 0;
  TIM2_CCER1 = 0x10;
  TIM2_CR1 |= 0x11;// 允许更新中断
{0x82, Timer2com}, /* irq11 */
{0x82, Timer2Isr}, /* irq12 */
@far @interrupt void Timer2com(void)
  if(TIM2_SR1&0x04==0x04)
  TIM2_SR1&=0xFB;
      test_var =  TIM2_CCR2H;
      test_var =  test_var*256+ TIM2_CCR2L;
test_var = 0;
return;
@far @interrupt void Timer2Isr(void)
TIM2_SR1&=0xFE;//清除更新中断标志位,否则仿真连续进入中断程序
return;
我就是进不去中断,计不了输入的数据
