请教版主STM32F205VC FSMC同步数据传输问题
4269|4
 楼主| xqscu 发表于 2012-10-30 15:46 | 显示全部楼层 |阅读模式
请教版主我将stm32f205vc的fsmc配置成同步传输,按照以下配置怎么Nwait信号不起作用,现象为nwait为高的时候fsmc没有插入等待时钟。void RamInit(void)
        FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
        FSMC_NORSRAMTimingInitTypeDef  p;
        /* Enable GPIOs clock */
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE |
                               RCC_AHB1Periph_GPIOB, ENABLE);
        /* Enable FSMC clock */
        RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
        /* GPIOD configuration */
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
        //GPIO_PinAFConfig(GPIOD, GPIO_PinSource2, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource3, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        //GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1  | GPIO_Pin_3 | GPIO_Pin_4  | GPIO_Pin_5  |
                GPIO_Pin_7 | GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10 | GPIO_Pin_11 |
                        GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        //GPIOB configuration
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_FSMC);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* GPIOE configuration */
        //GPIO_PinAFConfig(GPIOE, GPIO_PinSource0 , GPIO_AF_FSMC);
        //GPIO_PinAFConfig(GPIOE, GPIO_PinSource1 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource2 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource3 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource4 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource5 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource6 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2  | GPIO_Pin_3 |
                GPIO_Pin_4  | GPIO_Pin_5  | GPIO_Pin_6  | GPIO_Pin_7 |
                        GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10 | GPIO_Pin_11|
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        /*-- FSMC Configuration ------------------------------------------------------*/
        p.FSMC_AddressSetupTime = 0;
        p.FSMC_AddressHoldTime = 0;
        p.FSMC_DataSetupTime = 0;
        p.FSMC_BusTurnAroundDuration = 15;
        p.FSMC_CLKDivision = 15;
        p.FSMC_DataLatency = 0;
        p.FSMC_AccessMode = FSMC_AccessMode_D;
        FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
        FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Enable;
        FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_PSRAM;
        FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
        FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Enable;
        FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Enable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_High;
        FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
        FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Enable;
        FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Enable;
        FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
        FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
        FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
        /*!< Enable FSMC Bank1_SRAM2 Bank */
        FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
 楼主| xqscu 发表于 2012-10-30 17:55 | 显示全部楼层
有人做过fsmc同步读写的吗?
 楼主| xqscu 发表于 2012-10-30 19:45 | 显示全部楼层
搞定了, p.FSMC_DataLatency = 0;非等于0就可以了
zhaoshuaiabc 发表于 2013-8-8 21:50 | 显示全部楼层
楼主在吗?我在做FSMC同步数据传输,有些问题想请教一下楼主,不知道可否方便,我的qq是177260577~求楼主指导啊~主要是初始化问题和器件的选择问题~~~
linfeng24 发表于 2013-8-9 00:34 | 显示全部楼层
哈哈,自己解决就好。
