如何安装XILINX Floating License.
2672|4
星星之火红|  楼主 | 2012-11-2 13:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GoldSunMonkey| | 2012-11-2 14:40 | 只看该作者
供参考。
Floating License Installation on Servers
For existing FLEXnet license servers, a common practice is to copy the contents of the
license file into the existing license file
on your FLEXnet server.
Note: Restart the floating license server to enable the Xilinx licenses.
For New License Servers
1. Got the license.
2. Unzip these utilities into a destination directory. Xilinx recommends you place this
directory into your application search path.
3. Once the FLEXnet utilities are installed, run the following commands to start the floating
license server:
Linux
- <Server Tool directory>/bin/lin/lmgrd -c <path_to_license>/Xilinx.lic -l
<path_to_license>/log1.log
- <Server Tool directory> bin/lin64/lmgrd -c <path_to_license>/Xilinx.lic -l
° Windows
- < Server Tool directory>\bin\nt\lmgrd -c <path_to_license>\Xilinx.lic –l
<path_to_license>\log1.log
- < Server Tool directory>\bin\nt64\lmgrd -c <path_to_license>\Xilinx.lic –l
Client Machines Pointing to a Floating License
1. Run the Xilinx License Configuration Manager (XLCM).
UG798 (v2012.3, v14.3) October 16, 2012
Installing Your License Key File
2. Click the Manage Xilinx Licenses tab.
3. On the Manage Xilinx Licenses tab, enter the network path to the license server in the
port@server format into the XILINXD_LICENSE_FILE field. Click Set. The default Xilinx
port number is 2100.
4. For Linux operating systems, licensing environment variables cannot be set using the
Xilinx License Configuration Manager (XLCM). The environment variable fields are read
only, and they are grayed out and there are no Set buttons. The environment variable
must be set using the appropriate shell and commands
评分
参与人数 1威望 +1 收起 理由
xjsxjtu + 1
GoldSunMonkey| | 2012-11-2 14:43 | 只看该作者
英文资料,供参考。
xjsxjtu| | 2012-11-4 20:26 | 只看该作者
谢谢分享啊
GoldSunMonkey| | 2012-11-4 20:36 | 只看该作者
:)不客气。
