问大家一个小问题,请大家帮忙解答一下,关于LWIP的TCP
2107|0
 楼主| onbluesun 发表于 2012-11-2 15:11 | 显示全部楼层 |阅读模式
lwIP, TCP, ST, TE, pc
我现在已经比较清楚如何建立TCP连接,发送TCP数据了,但是现在我想,如果PA0由高电平变化到低电平,那么单片机就向电脑不停地发送十六进制1,这段代码怎么加在程序里面呢?下面贴出我原来的代码,这段代码原本是用于TELNET上面,但是我只要有TCP数据就可以了。
  1. #include "ziji.h"
  2. #include "stm3210c_eval_lcd.h"
  3. #include "lwip/tcp.h"
  4. #include <string.h>
  5. #include <stdio.h>
  6. #define GREETING "欢迎进入8001端口\n\r\n\r"
  7. extern const uint8_t STM32F10x_STR[];
  8. #define HELLO "回答:"
  9. #define MAX_NAME_SIZE 32
  10. extern const uint8_t STM32F10x_STR[];
  11. {
  12.   int length;
  13.   char bytes[MAX_NAME_SIZE];
  14. };
  15. static err_t ziji_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err);
  16. static err_t ziji_accept(void *arg, struct tcp_pcb *pcb, err_t err);
  17. static void ziji_conn_err(void *arg, err_t err);
  18. static err_t ziji_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
  19. {
  20.   struct pbuf *q;
  21.   struct name *name = (struct name *)arg;
  22.   int done;
  23.   char *c;
  24.   int i;
  25.   if (p != NULL)
  26.   {
  27.         tcp_recved(pcb, p->tot_len);
  28.         if(!name)
  29.     {
  30.       pbuf_free(p);
  31.       return ERR_ARG;
  32.     }
  33.     done = 0;
  34.     for(q=p; q != NULL; q = q->next)
  35.     {
  36.       c = q->payload;
  37.       for(i=0; i<q->len && !done; i++)
  38.           {
  39.         done = ((c == '\r') || (c == '\n'));
  40.         if(name->length < MAX_NAME_SIZE)
  41.             {
  42.           name->bytes[name->length++] = c;
  43.         }
  44.       }
  45.     }
  46.     if(done)
  47.     {
  48.       if(name->bytes[name->length-2] != '\r' || name->bytes[name->length-1] != '\n')
  49.           {
  50.         if((name->bytes[name->length-1] == '\r' || name->bytes[name->length-1] == '\n') && (name->length+1 <= MAX_NAME_SIZE))
  51.             {
  52.               name->length += 1;
  53.         }
  54.             else if(name->length+2 <= MAX_NAME_SIZE)
  55.             {
  56.           name->length += 2;
  57.         }
  58.             else
  59.             {
  60.           name->length = MAX_NAME_SIZE;
  61.         }
  62.         name->bytes[name->length-2] = '\r';
  63.         name->bytes[name->length-1] = '\n';
  64.       }
  65.       tcp_write(pcb, HELLO, strlen(HELLO), 1);
  66.       tcp_write(pcb, name->bytes, name->length, TCP_WRITE_FLAG_COPY);
  67.
  68.       tcp_write(pcb, "\n\r", strlen("\n\r"), 1);
  69.
  70.       name->length = 0;
  71.     }
  72.
  73.     pbuf_free(p);
  74.   }
  75.   else if (err == ERR_OK)
  76.   {
  77.     mem_free(name);
  78.     return tcp_close(pcb);
  79.   }
  80.   return ERR_OK;
  81. }
  82. static err_t ziji_accept(void *arg, struct tcp_pcb *pcb, err_t err)
  83. {
  84.   u32_t IPaddress;
  85.   u8_t iptxt[50];
  86.   volatile u8_t iptab[4];
  87.
  88.   IPaddress = pcb->remote_ip.addr;
  89.
  90.   iptab[0] = (u8_t)(IPaddress >> 24);
  91.   iptab[1] = (u8_t)(IPaddress >> 16);
  92.   iptab[2] = (u8_t)(IPaddress >> 8);
  93.   iptab[3] = (u8_t)(IPaddress);
  94.
  95.   LCD_DisplayStringLine(Line5, iptxt);
  96.
  97.   tcp_arg(pcb, mem_calloc(sizeof(struct name), 1));
  98.
  99.   tcp_err(pcb, ziji_conn_err);
  100.   tcp_recv(pcb, ziji_recv);
  101.
  102.   tcp_write(pcb, GREETING, strlen(GREETING), 1);
  103.
  104.   return ERR_OK;
  105. }
  106. void ziji_init(void)
  107. {
  108.   struct tcp_pcb *pcb;
  109.
  110.   pcb = tcp_new();
  111.   tcp_bind(pcb, IP_ADDR_ANY, 8001);
  112.   pcb = tcp_listen(pcb);
  113.   tcp_accept(pcb, ziji_accept);
  114.
  115. }
  116. static void ziji_conn_err(void *arg, err_t err)
  117. {
  118.   struct name *name;
  119.   name = (struct name *)arg;
  120.   mem_free(name);
  121. }
请教大家,到底怎么修改呢?
