显示2次成功,然后一直失败
2246|10
 楼主| chenho 发表于 2012-11-18 16:59 | 显示全部楼层 |阅读模式
使用68013的slave FIFO模式来传输数据,上位机发送数据,下位可以准确收到,但是下位机给上位机发送数据,则显示2次成功,然后一直失败,弄了好久,不知其原因。
gongche 发表于 2012-11-18 17:01 | 显示全部楼层
估计你的初始化配置有问题
 楼主| chenho 发表于 2012-11-18 17:02 | 显示全部楼层
等会,那我把初始化的代码贴上来给大家看看
 楼主| chenho 发表于 2012-11-18 17:04 | 显示全部楼层
void TD_Init( void )
  CPUCS = 0x12;
  IFCONFIG = 0x43;
  PORTACFG = 0x40;
  SYNCDELAY;
  FIFOPINPOLAR = 0x00;  // set all slave FIFO interface pins as active low PKTEND OR SLOE SLWR LOW AVTIVE
  SYNCDELAY;
  REVCTL = 0x03;        // enable the external master
  SYNCDELAY;            //reset the fifos
  FIFORESET = 0x80;
  SYNCDELAY;
  FIFORESET = 0x02;
  SYNCDELAY;
  FIFORESET = 0x04;
  SYNCDELAY;
  FIFORESET = 0x06;
  SYNCDELAY;
  FIFORESET = 0x08;
  SYNCDELAY;
  FIFORESET = 0x00;
  SYNCDELAY;
  PINFLAGSAB = 0x00;         // PINFLAGSAB = 0xE0; FLAGA - indexed, FLAGB - EP6 FF ;
  SYNCDELAY;
  PINFLAGSCD = 0x00;        // PINFLAGSCD = 0x08; FLAGC - EP2 EF, FLAGD - indexed;
  SYNCDELAY;                    // config the endpoints direction
  EP1OUTCFG = 0xA0;        //enable and bulk type
  EP1INCFG =  0xA0;
  SYNCDELAY;                    // see TRM section 15.14
  EP2CFG = 0xA0;
  SYNCDELAY;
  EP8CFG = 0xE0;
  SYNCDELAY;
  EP4CFG = 0x00;
  SYNCDELAY;
  EP6CFG = 0x00;
  SYNCDELAY;
  OUTPKTEND = 0X82;             //arming endpoint 2, perform OUTPKTEND 4 times since EP2 is 4x buffered
  SYNCDELAY;
  OUTPKTEND = 0X82;
  SYNCDELAY;
  OUTPKTEND = 0X82;
  SYNCDELAY;
  OUTPKTEND = 0X82;
  SYNCDELAY;
  EP2FIFOCFG = 0x10;        //EP IS AUTOOUT=0 AUTOIN =1 ZEROLEN=1 WORDIDE=0
  SYNCDELAY;
  EP8FIFOCFG = 0x08;        //EP IS AUTOOUT=0 AUTOIN =1 ZEROLEN=1 WORDIDE=0
  SYNCDELAY;
  INPKTEND = 0x08;
  SYNCDELAY;
  INPKTEND = 0x08;
  SYNCDELAY;
  EP8AUTOINLENH = 0x02;   //set the packet size 512
  SYNCDELAY;
  EP8AUTOINLENL = 0x00;
  SYNCDELAY;
  EP2BCL = 0x80;                // arm EP2OUT by writing byte count w/skip.
  SYNCDELAY;
  EP2BCL = 0x80;
  SYNCDELAY;
wenfen 发表于 2012-11-18 17:07 | 显示全部楼层
下位机传到PC,属于IN传输,首先要确认IN Endpoint配置是否有问题。
zhuhuis 发表于 2012-11-18 17:07 | 显示全部楼层
你可以设置成AUTOIN模式,EPxAUTOINLENH来设置要传输的数据大小。
huwr 发表于 2012-11-18 17:11 | 显示全部楼层
FIFO端点在Auto-In模式可以如下,数据手册也有说道:
1. Configure bits IFCONFIG[7:4] to define the behavior of
the interface clock.
2. Set bits IFCFG1:0=11.
3. Set REVCTL.0 and REVCTL.1 to ‘1’.
4. Configure EPxCFG.
5. Reset the FIFOs.
6. Set bit EPxFIFOCFG.3=1.
7. Set the size through the EPxAUTOINLENH registers.
冰清玉洁 发表于 2012-11-18 17:13 | 显示全部楼层
你是不是还在搞usb啊?这个好像是fifo满了吧,后面不能发送了
 楼主| chenho 发表于 2012-11-18 17:15 | 显示全部楼层
哦,我明白了,多谢
先结贴了
huanben 发表于 2012-11-18 20:05 | 显示全部楼层
10# chenho
LZ最后怎么解决的?
