定时器触发AD采样+DMA传输,这样配置DMA只能传输一轮么?
2983|6
 楼主| hackthree 发表于 2012-11-28 15:42 | 显示全部楼层 |阅读模式
初始化配置代码如下:(来自LifeRacing的这几天做的一个测量信号频谱的东西(开源),感谢LifeRacing的开源)
  1. void ADC1_Sample_Configuration(void)
  3.         ADC_InitTypeDef        ADC_InitStructure;
  4.         DMA_InitTypeDef         DMA_InitStructure;
  5.         TIM_OCInitTypeDef                TIM_OCInitStructure;
  6.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  7.         TIM_DeInit(TIM2);
  8.         TIM_TimeBaseStructure.TIM_Period = 1999;
  9.          TIM_TimeBaseStructure.TIM_Prescaler = 342;
  10.          TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  11.          TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  12.          TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  13.          TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  14.          TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  15.          TIM_OCInitStructure.TIM_Pulse = 0x7F;
  16.             TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  17.            TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  18.          TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
  19.          TIM_ARRPreloadConfig(TIM2, ENABLE);
  20.          TIM_Cmd(TIM2, ENABLE);
  21.         DMA_DeInit(DMA1_Channel1);
  22.         DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  23.         DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_Buffer[0];
  24.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  25.         DMA_InitStructure.DMA_BufferSize = 256;
  26.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  27.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  28.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  29.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  30.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  31.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  32.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  33.         DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  34.         DMA_Cmd(DMA1_Channel1, ENABLE);
  35.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  36.         ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  37.         ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  38.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2;
  39.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右对齐
  40.         ADC_InitStructure.ADC_NbrOfChannel = 1;//转换通道为通道一
  41.         ADC_Init(ADC1, &ADC_InitStructure);
  42.         ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_71Cycles5);
  43.           ADC_DMACmd(ADC1, ENABLE);
  44.         ADC_Cmd(ADC1, ENABLE);
  45.         ADC_ResetCalibration(ADC1);
  46.           while(ADC_GetResetCalibrationStatus(ADC1));
  47.         ADC_StartCalibration(ADC1);
  48.         while(ADC_GetCalibrationStatus(ADC1));
  49.         ADC_ExternalTrigConvCmd( ADC1, ENABLE);
  50. }
应用代码如下:
  1. if(DMA_GetFlagStatus(DMA1_FLAG_TC1) != RESET)
  3.    。。。。。。。。。。。
  4.    。。。。。。。。。。。
  5.     DMA_ClearFlag(DMA1_FLAG_TC1);
  6. }
定时器触发AD转换+DMA传输。
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //连续循环模式
ADC_Buffer[255]数组里的数据为什么只更新一次?
即当定时器触发AD转换了255个数,经过DMA传输之后,判断DMA转换完成,清除了完成标志之后,
DMA不再传输下一轮的转换。
ADC_Buffer[255]的数组中只有一次255个数,不再更新,但是AD此时还是在转换,只是DMA不再传输了。
为什么 ?
st316 发表于 2012-11-28 23:42 | 显示全部楼层
这样配置是没问题的,问题出在哪,慢慢调试下
 楼主| hackthree 发表于 2012-11-29 07:46 | 显示全部楼层
2# st316
调试 好长 时间 了 。。
jesterma 发表于 2012-11-29 09:21 | 显示全部楼层
试试看在ADC配置最后加一句 ADC_SoftwareStartConvCmd( ADC1, ENABLE );
 楼主| hackthree 发表于 2012-11-29 14:30 | 显示全部楼层
定时器外部触发,和软件启动没关系吧?
 楼主| hackthree 发表于 2012-11-29 14:31 | 显示全部楼层
4# jesterma
定时器外部触发,和软件启动没关系吧?
再说,ADC一直是在工作着的 。。
jesterma 发表于 2012-11-29 14:49 | 显示全部楼层
你的buffer到底有多长?是255还是256?
