tms320c5502连接不上
3069|2
1120019|  楼主 | 2012-11-28 21:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的板子连不上,出现以下情况;Error connecting to the target:
Error 0x80000242/-1143
Fatal Error during: Memory, Initialization, OCS,
The memory at 0x000000BE continually indicated it was 'not ready'
All memory operations currently in progress were aborted in order
to regain control of the processor.
This is considered a catastrophic event, but the debugger should
still be able to access memory and CPU registers.
System state has been altered.  It is strongly advised
that the processor should be reset before resuming execution,
Sequence ID: 0
Error Code: -1143
Error Class: 0x80000242
I/O Port = 240
Board Name: C5502 XDS510 Emulator
Cpu Name: CPU_1
Abort:
Close Code Composer Studio.
Retry:
Try to connect to the target again.
Cancel:
Remain disconnected from the target
我确定仿真器没坏,我也测了dsp的晶振复位没问题,时钟输出也有输出,bootloader直接就设置成了外部flash自举,我真不知道哪出问题了
Diagnostic:
Run diagnostic utility.
yongjinisme| | 2013-1-19 16:55 | 只看该作者
我也遇见同样的问题,没有高手回帖啊!!!
smilingangel| | 2013-1-20 15:32 | 只看该作者
看一下的,我暂时也没解决办法的,帮着先顶起了啊
