28031仿真出错
4036|5
 楼主| xichengmadia 发表于 2012-11-29 11:02 | 显示全部楼层 |阅读模式
刚学用C2000,自己做的一个小板子,今天仿真时出错了。
软件用的CCS V5.2  仿真器用的xds100 v2;直接导入的官方示例代码用来仿真。
.out load failed
错误提示:
C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: GEL: Error while executing OnReset(1): target access failed  at (ST1&~(0x0100)) [f28031.gel:282]  at C28x_Mode() [f28031.gel:32]  at OnReset(1) .
C28xx: Flash Programmer: Error erasing flash memory. Device is locked or not connected. Operation cancelled
C28xx: Flash Programmer: Error erasing Flash memory.
C28xx: Error resuming a profile counter: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x3f75f6 on Page 0 of Length 0x16: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: GEL: File: C:\ti\tidcs\c28\DSP2803x\v121\DSP2803x_examples\cpu_timer\Debug\Example_2803xCpuTimer.out: Load failed.
rcengtian 发表于 2014-1-6 18:04 | 显示全部楼层
这个帖子怎么没有答案??我也是同样的问题呀。
rcengtian 发表于 2014-1-7 14:11 | 显示全部楼层
youluo235 发表于 2014-1-7 23:08 | 显示全部楼层
驱动被锁了。有没有设置对。设置仿真器的型号以及目标器件的选型?
如果设置对了的话建议官网下程序导入下载。
