DC5V 转 DC36V
2263|4
 楼主| JSDTAF100 发表于 2012-11-30 13:13 | 显示全部楼层 |阅读模式
有没有好的DC-DC芯片把直流5V转为直流36V,我想买个DC-DC模块,但是36V貌似没这个档,只好自己搭个,找了好久没找到合适的,功率不大,救给两运放供电用的,急啊急
QQ1838766976 发表于 2012-11-30 13:50 | 显示全部楼层
一般运放工作电压都很宽的,你可以选个常用的电压
jjjyufan 发表于 2012-11-30 16:41 | 显示全部楼层
现成的模块,电压接近,电流合适,
基本改变反馈电阻是可以调整到36V的
trevor2011 发表于 2012-12-2 06:50 | 显示全部楼层
可以参考下TI的TPS61070:
http://www.ti.com/product/tps61170
The TPS61170 is a monolithic, high-voltage switching regulator with integrated 1.2-A, 40-V power MOSFET. It can be configured in several standard switching-regulator topologies, including boost and SEPIC. The device has a wide input-voltage range to support applications with input voltage from multi-cell batteries or regulated 5-V, 12-V power rails.
trevor2011 发表于 2012-12-2 06:51 | 显示全部楼层
或者LMR64010 都是集成MOSFET管的
http://www.ti.com/product/lmr64010
