TCP程序
2083|0
 楼主| mcpc 发表于 2007-4-18 22:06 | 显示全部楼层 |阅读模式
TCP, ip, se, ST, AD
void tcp_send(UINT flags, UINT hdr_len, UCHAR nr)
   ULONG idata sum, dest;
      UINT idata result;
   UCHAR xdata * outbuf;
   TCP_HEADER xdata * tcp;
   IP_HEADER xdata * ip;
   outbuf = outbuf1;
   tcp = (TCP_HEADER xdata *)(outbuf + 34);
   ip = (IP_HEADER xdata *)(outbuf + 14);
      if (nr == NO_CONNECTION)
      tcp->source_port = HTTP_PORT;
      tcp->dest_port = sender_tcpport;
      tcp->sequence = 0;
      tcp->ack_number = 0;
      dest = sender_ipaddr;
   else if (nr < 5)
      // This message is to connected port
      tcp->dest_port = conxn[nr].port;
      tcp->sequence = conxn[nr].my_sequence;
      tcp->ack_number = conxn[nr].his_sequence;
      dest = conxn[nr].ipaddr;
   else
        return;
   tcp->flags = (hdr_len << 10) | flags;  //?????????????
   tcp->window = 1024;
   tcp->checksum = 0;
   tcp->urgent_ptr = 0;
   if (hdr_len == 28)
      memcpy(&tcp->options, opt, 8);
    ip->dest_ipaddr = dest;
    ip->source_ipaddr = my_ipaddr;
    sum = (ULONG)cksum(outbuf + 26, 8 + hdr_len);
    sum += (ULONG)0x0006;
    sum += (ULONG)hdr_len;
    result = (UINT)(sum + (sum >> 16));
    tcp->checksum = ~result;
    ip_send(outbuf, dest, TCP_TYPE, hdr_len);
   conxn[nr].timer = TCP_TIMEOUT;
我觉得这个程序没有把TCP信息封装到IP层去,不知道正确与否,请大家指正
