ADC10为什么进不了中断
2194|6
 楼主| CATA_LYST 发表于 2012-12-5 15:12 | 显示全部楼层 |阅读模式
ADC1, TI, TE, se, hz
void main(void)
        WDTCTL = WDTPW + WDTHOLD;
        // Stop watchdog timer to prevent time out reset
        if (CALBC1_8MHZ == 0xFF || CALDCO_8MHZ == 0xFF)
             while(1);   // If calibration constants erased, trap CPU!!
        // Configure Basic Clock
        BCSCTL1 = CALBC1_8MHZ;     // Set range
        DCOCTL = CALDCO_8MHZ;    // Set DCO step + modulation*/
        ADC10CTL0= ADC10ON+REFON+ADC10SHT_3+MSC+ADC10IE+SREF_1;
        ADC10CTL1= CONSEQ_3+INCH_10;
        ADC10CTL0&=~ADC10IFG;
        _EINT();//打开中断
        __delay_cycles(10);
        while(1)
          while (ADC10CTL1 & BUSY);// Wait if ADC10 core is active
          ADC10SA = 0x200;         // Data buffer start
      ADC10CTL0 |= ENC+ADC10SC;//使能转换并且开始转换
      __delay_cycles(1);
      display();
#pragma vector=ADC10_VECTOR
__interrupt void ADC10ISR(void)
        char index=0;
        int i;
        results[index++]=ADC10MEM;
        if(index==NUM)
                unsigned long sum,real;
                index=0;
                for(i=0;i<NUM;i++)
                        sum+=results[i];
                sum>>=5;        //除以32求平均值
                real=((1.5*sum/1023)-0.986)/0.00355;//扩大1000倍
                data_temp[3]=real/1000;                                        //千位
                data_temp[2]=(real%1000)/1000;                        //百位
                data_temp[1]=real%100/10;                                //十位
                data_temp[0]=real%10;                                        //个位
                __delay_cycles(10);
                //display();
        ADC10CTL0&=~ADC10IFG;//清除中断标志
 楼主| CATA_LYST 发表于 2012-12-5 15:16 | 显示全部楼层
当把这一栏注释掉时
数码管都显示0,没有采集到数据,不知道为什么挂死在这里
 楼主| CATA_LYST 发表于 2012-12-5 15:18 | 显示全部楼层
 楼主| CATA_LYST 发表于 2012-12-5 15:30 | 显示全部楼层
永远的不知 发表于 2012-12-5 20:42 | 显示全部楼层
可以参考如下例程:
//  MSP430F20x2 Demo - ADC10, Sample A1, AVcc Ref, Set P1.0 if > 0.5*AVcc
//  Description: A single sample is made on A1 with reference to AVcc.
//  Software sets ADC10SC to start sample and conversion - ADC10SC
//  automatically cleared at EOC. ADC10 internal oscillator times sample (16x)
//  and conversion. In Mainloop MSP430 waits in LPM0 to save power until ADC10
//  conversion complete, ADC10_ISR will force exit from LPM0 in Mainloop on
//  reti. If A1 > 0.5*AVcc, P1.0 set, else reset.
//                MSP430F20x2
//         /|\|              XIN|-
//          --|RST          XOUT|-
//        >---|P1.1/A1      P1.0|-->LED
//  L. Westlund
//  Texas Instruments Inc.
//  May 2006
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include "msp430x20x2.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; // ADC10ON, interrupt enabled
  ADC10CTL1 = INCH_1;                       // input A1
  ADC10AE0 |= 0x02;                         // PA.1 ADC option select
  P1DIR |= 0x01;                            // Set P1.0 to output direction
  for (;;)
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    if (ADC10MEM < 0x1FF)
      P1OUT &= ~0x01;                       // Clear P1.0 LED off
    else
      P1OUT |= 0x01;                        // Set P1.0 LED on
// ADC10 interrupt service routine
__interrupt void ADC10_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
yiyanzhong 发表于 2012-12-5 22:39 | 显示全部楼层
输出显示的0应该是初始化的值,很可能是没有AD采样,你可以单步调试观察一下ADC10MEM的值有没有变化,检查一下触发中断的条件是不是满足
comeon201208 发表于 2012-12-6 09:39 | 显示全部楼层
一大早的跟各位学习啦,谢谢楼主
