stm32出现下面错误
2669|1
 楼主| 西北地CBD 发表于 2012-12-7 23:07 | 显示全部楼层 |阅读模式
..\CM3\stm32f10x.h(96): error:  #35: #error directive: "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)"
  对应的代码是
#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL)
#error "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)"
#endif
#if !defined  USE_STDPERIPH_DRIVER
跪求解释。。。
amwrdfe 发表于 2012-12-7 23:27 | 显示全部楼层
定义好全局标志.类似
