stm32f103ve 外扩fsmc nand flash K9k8g08u0m 读写不成功
5562|8
 楼主| iamyj2007 发表于 2012-12-12 15:57 | 显示全部楼层 |阅读模式
求助 stm32f103ve 外扩fsmc nand flash K9f1g08u0m读写成功 换成K9k8g08u0m后读写不成功
以下为stm32f103ve 外扩fsmc nand flash K9f1g08u0m读写程序
#include "fsmc_nand.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define FSMC_Bank_NAND     FSMC_Bank2_NAND
#define Bank_NAND_ADDR     Bank2_NAND_ADDR
#define Bank2_NAND_ADDR    ((u32)0x70000000)
/* Private macro -------------------------------------------------------------*/
#define ROW_ADDRESS (Address.Page + (Address.Block + (Address.Zone * NAND_ZONE_SIZE)) * NAND_BLOCK_SIZE)
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : FSMC_NAND_Init
* Description    : Configures the FSMC and GPIOs to interface with the NAND memory.
*                  This function must be called before any write/read operation
*                  on the NAND.
* Input          : None
* Output         : None
* Return         : None
void FSMC_NAND_Init(void)
  FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
  FSMC_NAND_PCCARDTimingInitTypeDef  p;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                         RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/
/* CLE, ALE, D0->D3, NOE, NWE and NCE2  NAND pin configuration  */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_14 | GPIO_Pin_15 |
                                 GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
                                 GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
/* D4->D7 NAND pin configuration  */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
/* NWAIT NAND pin configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
/* INT2 NAND pin configuration */
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
// GPIO_Init(GPIOG, &GPIO_InitStructure);
  /*-- FSMC Configuration ------------------------------------------------------*/
  p.FSMC_SetupTime = 0x1;
  p.FSMC_WaitSetupTime = 0x3;
  p.FSMC_HoldSetupTime = 0x2;
  p.FSMC_HiZSetupTime = 0x1;
  FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND;
  FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable;
  FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
  FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable;
  //FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_512Bytes;
  // for Hynix HY27UF081G2A
  FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_2048Bytes;
  FSMC_NANDInitStructure.FSMC_AddressLowMapping = FSMC_AddressLowMapping_Direct;
  FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
  FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
  FSMC_NANDInit(&FSMC_NANDInitStructure);
  /* FSMC NAND Bank Cmd Test */
  FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
* Function Name  : FSMC_NAND_ReadID
* Description    : Reads NAND memory's ID.
* Input          : - NAND_ID: pointer to a NAND_IDTypeDef structure which will hold
*                    the Manufacturer and Device ID.
* Output         : None
* Return         : None
void FSMC_NAND_ReadID(NAND_IDTypeDef* NAND_ID)
  u32 data = 0;
  /* Send Command to the command area */
  *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = 0x90;
  *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;
   /* Sequence to read ID from NAND flash */
   data = *(vu32 *)(Bank_NAND_ADDR | DATA_AREA);
   NAND_ID->Maker_ID   = ADDR_1st_CYCLE (data);
   NAND_ID->Device_ID  = ADDR_2nd_CYCLE (data);
   NAND_ID->Third_ID   = ADDR_3rd_CYCLE (data);
   NAND_ID->Fourth_ID  = ADDR_4th_CYCLE (data);
* Function Name  : FSMC_NAND_WriteSmallPage
* Description    : This routine is for writing one or several 512 Bytes Page size.
* Input          : - pBuffer: pointer on the Buffer containing data to be written
*                  - Address: First page address
*                  - NumPageToWrite: Number of page to write
* Output         : None
* Return         : New status of the NAND operation. This parameter can be:
*                   - NAND_TIMEOUT_ERROR: when the previous operation generate
*                     a Timeout error
*                   - NAND_READY: when memory is ready for the next operation
*                  And the new status of the increment address operation. It can be:
*                  - NAND_VALID_ADDRESS: When the new address is valid address
*                  - NAND_INVALID_ADDRESS: When the new address is invalid address
u32 FSMC_NAND_WriteSmallPage(u8 *pBuffer, NAND_ADDRESS Address, u32 NumPageToWrite)
  u32 index = 0x00, numpagewritten = 0x00, addressstatus = NAND_VALID_ADDRESS;
  u32 status = NAND_READY, size = 0x00;
  while((NumPageToWrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
    /* Page write command and address */
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_PAGEPROGRAM;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = 0X00;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(ROW_ADDRESS);
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS);
    /* Calculate the size */
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpagewritten);
    /* Write data */
    for(; index < size; index++)
      *(vu8 *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_PAGEPROGRAM_TRUE;
    while( GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == 0 );
    /* Check status for successful operation */
    status = FSMC_NAND_GetStatus();
    if(status == NAND_READY)
      numpagewritten++;
      NumPageToWrite--;
      /* Calculate Next small page Address */
      addressstatus = FSMC_NAND_AddressIncrement(&Address);
  return (status | addressstatus);
* Function Name  : FSMC_NAND_ReadSmallPage
* Description    : This routine is for sequential read from one or several
*                  512 Bytes Page size.
* Input          : - pBuffer: pointer on the Buffer to fill
*                  - NumPageToRead: Number of page to read
* Output         : None
*                     a Timeout error
u32 FSMC_NAND_ReadSmallPage(u8 *pBuffer, NAND_ADDRESS Address, u32 NumPageToRead)
  u32 index = 0x00, numpageread = 0x00, addressstatus = NAND_VALID_ADDRESS;
  while((NumPageToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
    /* Page Read command and page address */
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ_1;
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ_TRUE;
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpageread);
    /* Get Data into Buffer */
      pBuffer[index]= *(vu8 *)(Bank_NAND_ADDR | DATA_AREA);
    numpageread++;
    NumPageToRead--;
    /* Calculate page address */
* Function Name  : FSMC_NAND_WriteSpareArea
* Description    : This routine write the spare area information for the specified
*                  pages addresses.
*                  - NumSpareAreaTowrite: Number of Spare Area to write
* Output         : None
*                     a Timeout error
u32 FSMC_NAND_WriteSpareArea(u8 *pBuffer, NAND_ADDRESS Address, u32 NumSpareAreaTowrite)
  u32 index = 0x00, numsparesreawritten = 0x00, addressstatus = NAND_VALID_ADDRESS;
  while((NumSpareAreaTowrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
    /* Page write Spare area command and address */
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = 0x08;
    size = NAND_SPARE_AREA_SIZE + (NAND_SPARE_AREA_SIZE * numsparesreawritten);
    /* Write the data */
      numsparesreawritten++;
      NumSpareAreaTowrite--;
      /* Calculate Next page Address */
* Function Name  : FSMC_NAND_ReadSpareArea
* Description    : This routine read the spare area information from the specified
*                  pages addresses.
*                  - NumSpareAreaToRead: Number of Spare Area to read
* Output         : None
*                     a Timeout error
u32 FSMC_NAND_ReadSpareArea(u8 *pBuffer, NAND_ADDRESS Address, u32 NumSpareAreaToRead)
  u32 numsparearearead = 0x00, index = 0x00, addressstatus = NAND_VALID_ADDRESS;
  while((NumSpareAreaToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
    /* Data Read */
    size = NAND_SPARE_AREA_SIZE +  (NAND_SPARE_AREA_SIZE * numsparearearead);
    for ( ;index < size; index++)
      pBuffer[index] = *(vu8 *)(Bank_NAND_ADDR | DATA_AREA);
    numsparearearead++;
    NumSpareAreaToRead--;
* Function Name  : FSMC_NAND_EraseBlock
* Description    : This routine erase complete block from NAND FLASH
* Input          : - Address: Any address into block to be erased
* Output         : None
*                     a Timeout error
u32 FSMC_NAND_EraseBlock(NAND_ADDRESS Address)
  *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE0;
  *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE1;
  return (FSMC_NAND_GetStatus());
* Function Name  : FSMC_NAND_Reset
* Description    : This routine reset the NAND FLASH
* Input          : None
* Output         : None
* Return         : NAND_READY
u32 FSMC_NAND_Reset(void)
  *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_RESET;
  return (NAND_READY);
* Function Name  : FSMC_NAND_GetStatus
* Description    : Get the NAND operation status
* Input          : None
* Output         : None
*                     a Timeout error
u32 FSMC_NAND_GetStatus(void)
  u32 timeout = 0x1000000, status = NAND_READY;
  status = FSMC_NAND_ReadStatus();
  /* Wait for a NAND operation to complete or a TIMEOUT to occur */
  while ((status != NAND_READY) &&( timeout != 0x00))
     timeout --;
  if(timeout == 0x00)
    status =  NAND_TIMEOUT_ERROR;
  /* Return the operation status */
  return (status);
* Function Name  : FSMC_NAND_ReadStatus
* Description    : Reads the NAND memory status using the Read status command
* Input          : None
* Output         : None
* Return         : The status of the NAND memory. This parameter can be:
*                   - NAND_BUSY: when memory is busy
*                   - NAND_ERROR: when the previous operation gererates error
u32 FSMC_NAND_ReadStatus(void)
  u32 data = 0x00, status = NAND_BUSY;
  /* Read status operation ------------------------------------ */
  *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_STATUS;
  data = *(vu8 *)(Bank_NAND_ADDR);
  if((data & NAND_ERROR) == NAND_ERROR)
    status = NAND_ERROR;
  else if((data & NAND_READY) == NAND_READY)
  else
    status = NAND_BUSY;
  return (status);
* Function Name  : NAND_AddressIncrement
* Description    : Increment the NAND memory address
* Input          : - Address: address to be incremented.
* Output         : None
* Return         : The new status of the increment address operation. It can be:
u32 FSMC_NAND_AddressIncrement(NAND_ADDRESS* Address)
  u32 status = NAND_VALID_ADDRESS;
  Address->Page++;
  if(Address->Page == NAND_BLOCK_SIZE)
    Address->Page = 0;
    Address->Block++;
    if(Address->Block == NAND_ZONE_SIZE)
      Address->Block = 0;
      Address->Zone++;
      if(Address->Zone == NAND_MAX_ZONE)
        status = NAND_INVALID_ADDRESS;
  return (status);
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
uet_cache 发表于 2012-12-12 17:35 | 显示全部楼层
这么长的程序,好懒得看啊。楼主网上找现成的例子参考下吧。
figo20042005 发表于 2012-12-12 20:08 | 显示全部楼层
好长的程序,不知道LZ怀疑哪块
 楼主| iamyj2007 发表于 2012-12-13 16:27 | 显示全部楼层
就是按照网上观海听涛STM32学习笔记——FSMC 驱动大容量NAND FLASH的例子对小页进行进行修改的 但是可以对K9F1G08读写成功
小农wz 发表于 2012-12-14 18:00 | 显示全部楼层
 楼主| iamyj2007 发表于 2012-12-25 12:24 | 显示全部楼层
终于搞定了 原来少送了一位地址
uet_cache 发表于 2012-12-25 15:05 | 显示全部楼层
杨爱林林 发表于 2012-12-26 09:47 | 显示全部楼层
这么长的程序,谁有时间看完啊
irainboy 发表于 2019-9-7 22:32 | 显示全部楼层
大哥,请问一下,我用k9f1g08u0e读数据的时候一直同一数,不是我连续输进去的数,代码和您这一样
