[其他ST产品] 各位大神请看看这个程序为什么不能实现键盘扫描。用的是DS12C887芯片
2259|2
 楼主| 李威威0 发表于 2012-12-18 11:42 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
uchar code table[]=" 2012-12-12 SUN";
uchar code table1[]="     :  :  ";
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit FM=P2^3;
sbit cs=P1^2;
sbit as=P1^1;
sbit rw=P1^0;
sbit ds=P1^3;
sbit s1=P3^1;//功能键
sbit s2=P3^2;//增大键
sbit s3=P3^3;//减小键
sbit s5=P3^7; //前提键
char hour,min,sec,week,day,mon,year,asec,amin,ahour;
bit flag_ri,flag,flag1;
uchar k;
void delay(uchar z)
        uchar x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void di()
        FM=0;
        delay(100);
        FM=1;
void write_com(uchar com)
        rs=0;
        lcden=0;
        P0=com;
        lcden=1;
        delay(3);
        lcden=0;
void write_date(uchar date)
        rs=1;
        lcden=0;
        P0=date;
        lcden=1;
        delay(3);
        lcden=0;
void write_sfm(uchar add,uchar date)
        uchar a,b;
        a=date/10;
        b=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+a);
        write_date(0x30+b);
void write_ymd(uchar add,char date)
        char c,d;
        c=date/10;
        d=date%10;
        write_com(0x80+add);
        write_date(0x30+c);
        write_date(0x30+d);
void write_week(uchar k)  //星期
        write_com(0x80+12);
        switch(k)
                case 1:write_date('M');
                                write_date('O');
                                write_date('N');
                                break;
                case 2:write_date('T');
                                write_date('U');
                                write_date('E');
                                break;
                case 3:write_date('W');
                                write_date('E');
                                write_date('D');
                                break;
                case 4:write_date('T');
                                write_date('H');
                                write_date('U');
                                break;
                case 5:write_date('F');
                                write_date('R');
                                write_date('I');
                                break;
                case 6:write_date('S');
                                write_date('A');
                                write_date('T');
                                break;
                case 7:write_date('S');
                                write_date('U');
                                write_date('N');
                                break;
void write_del(uchar add,uchar date)
        cs=0;
        as=1;
        ds=1;
        rw=1;
        P0=add;
        as=0;
        rw=0;
        P0=date;
        rw=1;
        as=1;
        cs=1;
uchar read_del(uchar add)
        uchar date0;
        as=1;
        ds=1;
        rw=1;
        cs=0;
        P0=add;
        as=0;
        ds=0;
        P0=0xff;
        date0=P0;
        ds=1;
        as=1;
        cs=1;
        return date0;
void keyscan()
        s5=0;
        if(s1==0)
                delay(10);
                if(s1==0)
                        while(!s1);
                        di();
                        k++;
                        flag=1;
                        if(k==1)
                                write_com(0x80+0x40+9);
                                write_com(0x0f);
                        if(k==2)
                                write_com(0x80+0x40+6);
                        if(k==3)
                                write_com(0x80+0x40+3);
                        if(k==4)
                                k=0;
                                write_com(0x0c);
                                write_del(0,sec);
                                write_del(2,min);
                                write_del(4,hour);
        if(s1!=0)
                if(s2==0)
                        delay(1);
                        if(s2==0)
                                while(!s2);
                                di();
                                if(k==1)
                                        sec++;
                                        if(sec==60)
                                                sec=0;
                                        write_sfm(9,sec);
                                if(k==2)
                                        min++;
                                        if(min==60)
                                                min=0;
                                        write_sfm(6,min);
                                if(k==3)
                                        hour++;
                                        if(hour==24)
                                                hour=0;
                                        write_sfm(3,hour);
                if(s3==0)
                        delay(10);
                        if(s3==0)
                                while(!s3);
                                di();
                                if(k==1)
                                        sec--;
                                        if(sec==-1)
                                                sec=59;
                                        write_sfm(9,sec);
                                if(k==2)
                                        min--;
                                        if(min==-1)
                                                min=59;
                                        write_sfm(6,min);
                                if(k==3)
                                        hour--;
                                        if(hour==-1)
                                                hour=23;
                                        write_sfm(3,hour);
void init()
        uint i;
        wela=0;
        dula=0;
        lcden=0;
//        write_del(0x0a,0xa0);
        write_del(0x0b,0x27);
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x02);
        write_com(0x01);
        write_com(0x80);
        for(i=0;i<15;i++)
                write_date(table[i]);
                delay(3);
        write_com(0x80+0x40);
        for(i=0;i<11;i++)
                write_date(table1[i]);
                delay(3);
void main()
        init();
        while(1)
                        keyscan();
                        sec=read_del(0);
                        min=read_del(2);
                        hour=read_del(4);
                        week=read_del(6);
                        day=read_del(7);
                        if(day>=32)        day=1;
                        mon=read_del(8);
                        if(mon>=13)        mon=1;
                        year=read_del(9);
                        if(year>=100)        year=0;
                        write_sfm(9,sec);
                        write_sfm(6,min);
                        write_sfm(3,hour);
                        write_week(week);
                        write_ymd(9,day);
                        write_ymd(6,mon);
                        write_ymd(3,year);
当把keyscan函数去掉时可以准确计时,键盘声明正确
 楼主| 李威威0 发表于 2012-12-18 11:45 | 显示全部楼层
原理图
原理图
原理图
 楼主| 李威威0 发表于 2012-12-19 12:11 | 显示全部楼层
耶!经过自己的不断尝试终于调试好啦!
