[产品供应] CY3240-I2USB
1158|0
 楼主| szjlj168 发表于 2012-12-22 10:52 | 显示全部楼层 |阅读模式
USB, TE, AN, I2c, ic
The I2C-USB Kit allows one to test, tune and debug hardware and software of a PSoC application by bridging the USB port to I2C. Populated with the CY8C24894 PSoC device. A wide variety of devices can be connected to the PC using this bridge. Among them are: EEPROMs, realtime cLocks, ADC/DAC converters, LCD displays, regulated DC/DC converters, port expanders and many other devices incorporating the I2C interface. The number of devices that can be connected is constrained only by the I2C address limit and physical ability of the I2C bus.
CY3240-I2USB Rev. A Contents:
  • I2C-USB Bridge
  • I2C Slave Demonstration Board
  • USB Mini B Cable (6 feet)
  • Supporting Software CD
CYPRESS全系列产品,有大量的库存,而且有一群研发团队,对CYPRESS的开发应用相当成熟的,如果你们长期有用到CYPRESS的产品,即可以低价拿到新批次又可以得到工程团队的力量。 所有有关CY的,烧程序也好,设计方案也好,都会为您提供最优质的服务。
可以联系 巨**:QQ547838378  13692110307
个人签名:深圳永晟达电子科技有限公司专业代理:CYPRESS,Microchip,NXP,ST,ATMEL,TI,LTC,等系列原装进口IC 可代客户开发程序  QQ;547838378
4395
