问下KEIL C 里的INTRINS.H头文件的问题
2930|1
 楼主| 会流泪的鱼 发表于 2007-7-18 13:31 | 显示全部楼层 |阅读模式
我在网上看到有INTRINS.H的扩容工程,看起来不错,想把它用起来但不知道怎么用起来!!!!
具体如下~~~~~
INTRINS.H
Intrinsic functions for C51.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __INTRINS_H__
#define __INTRINS_H__
extern void          _nop_     (void);
extern bit           _testbit_ (bit);
extern unsigned char _cror_    (unsigned char, unsigned char);
extern unsigned int  _iror_    (unsigned int,  unsigned char);
extern unsigned long _lror_    (unsigned long, unsigned char);
extern unsigned char _crol_    (unsigned char, unsigned char);
extern unsigned int  _irol_    (unsigned int,  unsigned char);
extern unsigned long _lrol_    (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
#endif
        伪本征函数——Keil C51头文件INTRINS.H的扩容工程
                    作者:HotPower@126.com  2004.5.27  第二版
#define _setc_()          CY   = 1
#define _clrc_()          CY   = 0
#define _setb_(RBIT)      RBIT = 1
#define _clrb_(RBIT)      RBIT = 0
#define _clra_()          ACC  = 0
#define _xorr_(RX)        RX  ^= RX                  //用于取奇偶位P,且RX=0
#define _andr_(RX)        RX  &= RX                  //用于取奇偶位P,且RX=不变
#define _orr_(RX)         RX  |= RX                  //用于取奇偶位P,且RX=不变
#define _notr_(RX)        RX   =~RX
#define _movra_(RX)       RX   = ACC
#define _movar_(RX)       ACC  = RX
#define _movcb_(RBIT)     CY   = RBIT
#define _movbc_(RBIT)     RBIT = CY
#define _movb0_(RBIT, RX) RBIT = RX  & 0x01           //用于取RX的最低位
#define _movb7_(RBIT, RX) RBIT = RX  & 0x80           //用于取RX的最高位
#define _movc0_(RX)       CY   = RX  & 0x01
#define _movc7_(RX)       CY   = RX  & 0x80
#define _rrca_()          CY   = ACC & 0x01           //产生RRC A指令
#define _rlca_()          CY   = ACC & 0x80           //产生RLC A指令
#define _rrcr_(RX)        CY   = RX  & 0x01; RX = ACC //产生RRC RX指令
#define _rlcr_(RX)        CY   = RX  & 0x80; RX = ACC //产生RLC RX指令
               累加器带进位右移指令 RRC A
汇编代码       rrc a
               累加器带进位左移指令 RLC A
汇编代码       rlc a
               寄存器带进位右移指令 RRC REG
汇编代码       mov  a,RX
               rrc  a
   mov  RX,a
例:
C51程序
unsigned char i;
       i = 0x55;
   _setc_();//CY=1
       _rrcr_(i);//i=0xaa,ACC=0xaa,CY=1
汇编代码
       mov  r7,#055h
   setb c
   mov  a,r7
   rrc  a
       mov  r7,a
               寄存器带进位左移指令 RLC REG
#define _rlcar_(RX)       CY  = RX  & 0x80; RX  = ACC
汇编代码       mov  a,RX
               rlc  a
   mov  RX,a
例:
C51程序
unsigned char i;
       i = 0x55;
   _setc_();//CY=1
       _rlcr_(i);//i=0x55,ACC=0xab,CY=0
汇编代码
       mov  r7,#055h
   setb c
   mov  a,r7
   rlc  a
       mov  r7,a
  伪本征函数"汇编级"应用
1.写串行数据
C51程序
void writedata(unsigned char val)
  _movar_(val);//或用ACC = val;
  for (val = 8; val > 0; val--)
    _clrb_(TXD);//或用TXD = 0;
    _rrca_();
    _movbc_(RXD);//或用RXD = CY;
    _setb_(TXD);//或用TXD = 1;
_nop_();
A51代码
writedata:
    mov  a,r7
mov  r7,#8
writedata_loop:
    clr  txd
    rrc  a
mov  rxd,c
    setb txd
nop
djnz r7,writedata_loop
ret
2.读串行数据
C51程序
unsigned char readdata(void)
unsigned char val;
_nop_();
    _movcb_(RXD);//或用CY = RXD;
    _rrca_();
_nop_();
  _movra_(val);//或用val = ACC;
  return val;
A51代码
readdata:
mov  r7,#8
readdata_loop:
    clr  txd
nop
  mov  c,rxd
    rrc  a
    setb txd
nop
djnz r7,readdata_loop
mov  r7,a
ret
 楼主| 会流泪的鱼 发表于 2007-7-18 13:34 | 显示全部楼层
主要就是后面那段怎么加进来!!
就是这些,因为加起来感觉编起来C51的程序会紧凑点!!
