Warning: Found 3 output pins without output pin load capacitance assignment
6672|4
 楼主| zhaorj8780 发表于 2012-12-29 16:58 | 显示全部楼层 |阅读模式
Warning: The high junction temperature operating condition is not set. Assuming a default value of '85'.
Warning: The low junction temperature operating condition is not set. Assuming a default value of '0'.
        Info: Pin "out[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
        Info: Pin "out[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
        Info: Pin "out[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
结温如何设置,负载电容如何加,能给个图示吗
这些警告如何处理,不要告诉我不用管欧
GoldSunMonkey 发表于 2012-12-29 23:26 | 显示全部楼层
没分配管脚
 楼主| zhaorj8780 发表于 2012-12-31 17:31 | 显示全部楼层
管脚已经分配了,下载没问题,我只是想知道如何消除这些警告!
GoldSunMonkey 发表于 2013-1-3 22:58 | 显示全部楼层
这个ALTERA的么??找一下他们的图就知道了。如果功能正常不用管他。
xjsxjtu 发表于 2013-1-13 22:18 | 显示全部楼层
嗯,猴哥好热情啊
