STM32F103 I/O矩阵键盘扫描问题
5757|3
 楼主| lin34337151 发表于 2012-12-31 01:00 | 显示全部楼层 |阅读模式
void LocalKey_PE0_Config(void)
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOE, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   //P0口普推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;         //上拉输入
        GPIO_ResetBits(GPIOE, GPIO_Pin_0);
        GPIO_SetBits(GPIOE, GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4);
void LocalKey_PE1_Config(void)
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
        GPIO_ResetBits(GPIOE, GPIO_Pin_1);
        GPIO_SetBits(GPIOE, GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4);
void scankey()
    static uint8_t LocalKey_COUNT1,LocalKey_COUNT2,LocalKey_FLAG1,LocalKey_FLAG2;
        LocalKey_PE0_Config();
        __ScanKey_temp=(uint8_t)GPIO_ReadInputData(GPIOE);
        if((__ScanKey_temp&0x1e)!=0X1e)          //不等于有键按下
                 LocalKey_COUNT1++;
                if((LocalKey_COUNT1>125)&&(LocalKey_FLAG1==0))  //125个循环周期去抖动
                    LocalKey_FLAG1=1;
                        __ScanKey_temp=(uint8_t)GPIO_ReadInputData(GPIOE);          //再次读回数据
                        __ScanKey_temp=__ScanKey_temp&0x1e;
                        switch(__ScanKey_temp)
                                case 0X1c:          //分区1
                                        break;
                                case 0x1a:               //分区2
                                        break;
                                case 0x16:                   //分区3
                                        break;
                                case 0x0e:                   //分区4
                                        break;
                                default:
        else  //松开或者无按键
                LocalKey_FLAG1=0;
                LocalKey_COUNT1=0;
        LocalKey_PE1_Config();
        if((__ScanKey_temp&0x1d)!=0X1d)          //不等于有键按下
                 LocalKey_COUNT2++;
                if((LocalKey_COUNT2>125)&&(LocalKey_FLAG2==0))  //15个循环周期去抖动
                        LocalKey_FLAG2=1;
                        __ScanKey_temp=__ScanKey_temp&0x1d;
                                case 0X1c:                          //分区5
                                        break;
                                case 0x19:                                                        //分区6
                                        break;
                                case 0x15:                          //分区7
                                        break;
                                case 0x0d:                          //分区8
                                        break;
                                default:
        else
                LocalKey_FLAG2=0;
                LocalKey_COUNT2=0;
 楼主| lin34337151 发表于 2012-12-31 01:02 | 显示全部楼层
今天调试一个矩阵键盘扫描程序怎么都调不出来。请大侠是否可以指点一下。我用的是100脚的STM32F103VCT6,用PE0/1/2/3/4五个I/O加了1N4148扫描按键,第一组PE0=0,PE1/2/3/4=1;去读取PE1/2/3/4 四个I/O上的按键值,第二组PE1=0,PE0/2/3/4=1,读取PE0/2/3/4 I/O口上按键值。这两组我单独运行一组去读都正确,两组一起运行扫描的时候就扫不到按键,我之前操作51的时候都这么干,都可以扫描到按键,不知道是不是我哪里设置不对,还是STM32 I/O口在配置了之后要等待一会,赋0的I/O口我配置成推挽输出,赋1的I/O口配置成上拉输入
 楼主| lin34337151 发表于 2012-12-31 01:10 | 显示全部楼层
 楼主| lin34337151 发表于 2012-12-31 01:12 | 显示全部楼层
上面是我的电路图,请大侠指点一下,5个IO扫描20个按键,还有三组连接类似
