[产品供应]
长期供应CMD65 综合测试仪 刘颖13751017201
485|0
qq53593211|  楼主 | 2013-1-3 10:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
联系人:欧阳璋13510500080/刘颖13751017201
联系电话:0755-89518111
联系传真:0755-28532770
公司网址:www.cgilent.com
E-mail:aqqw21@126.com
QQ客服:53593211,
公司地址:深圳市深南中路国际科技大厦
大量库存,资金雄厚,服务快捷!
实体店销售、实行24小时全天候服务!
服务热线:158-8978-8248 彭先生
长期经营中古仪器仪表销售、回收、维修、租赁等业务!
品牌:R&S(罗德&施瓦茨)
型号:CMD65综合测试仪
•CMD65可靠性测量速度和性价比是使
•一种测试设备在市场上获得优势地位的关键性指标。
•在DECT( 数字欧洲无绳电话) 无线通信网络中大量的无线电话和固定站,
•CMD65必须分享十分有限的频率时间和空间资源。
•因此只有制订严格的标准或规范才能保证网络正常有序的运转。
•另一方面标准又要求DECT系统以及系统使用的话机应具有低廉的价格。
•CMD65这一点导致设 备结构复杂性和精度受到限制。
技术指标
Time and frequency reference
TCXO standard
Nominal frequency 10MHz
Temperfure effect(0 to 35℃) <1.5*10^-6
Aging <0.5*10^-6/year
OCXO option CMD-B1
Temperatureeffect(0to 50℃)
Aging 1*10^-7
<5*10^-9/day or <2*10^-7/year
DECT signal generator specificaitons validfor N connector
Frequency 10 DECt chanels 0 to 9
Additional DECT channels -3 to -1,10 to 12and half channels
Level range -100 to -40dBm
Burst switch-off >30dB
Modulation GFSK(B*T=0.5)
DECT analyzer specifications valid for N connector
Frequency
Level(setting for external offenuation and expected powershall be matching same as signal
generator
-10 to +30 to dBm) -65 to +30dBm(for level meter)
-30 to +30dBm(forbroadband FM demodulator and signalling),values shifted by about -40dB for
input2
FM demodulator for TX postprocessing and analog output
Range 0 to 450kHz deviation
Resolution 1kHz
Level meter(transientresponse) for TX posprocessing and analog output
Range -65to 30 to dBm
Dynamic 70dB
Analog DECT ADPCM interface
Output balanced
Range 1V,300Hz to 3kHz
S/N+THD 50dB of full-range level
Input balanced
Range 50mV,300Hzto 3kHz
S/N+THD 50dB at full-range level
DC measurements
DC voltmeter 0to ±30V
DC ammeter 0 to ±30A
AF meter
Frequency range 50Hzto 10kHz
Input voltage 0.1mV to 30V
Load impedance 1MΩ
AF distortion meter
Frequency range 300Hz to 3kHz
Input voltage 100mV to 30V
Loadimpedance 1MΩ
AF counter
Frequency range 20Hz to 10kHz
Input voltage 10mVto 30V
rESOLUTION 1Hz
Load impedance 1mΩ
60MHz counter
Frequency range 10Khz to 60MHz
Input signal min:100mV;max:TTL signal
Resolution 1Hz
Load impedance 1MΩ‖100pF
AFgenerator
Resolution 0.1Hz
Accuracy 0.05Hz
Output voltage 10μV to5V
Max.current 20mA
Source impedance <5Ω
附注:本公司专业经营各类二手进口仪器(销售、租赁业务),成色新,价格低,技术先进、质量可靠、性
能稳定的优良产品。长期承接销售、租赁、维修、回收二手高档仪器, 包括Agilent、HP、Anritsu、
Advantest、R/S、/MARCONI等世界知名品牌的网络分析仪、频谱分析仪、综合测试仪、数字通讯测试仪、
高频信号源、数字示波器、天馈线测试仪、电声测试仪,音频分析仪、等二手高频通讯测试仪器仪表的销
售及租赁业务。如果你遇到困难,我们都将全力以付的为你们提供最佳的方案。
