有用过C2000的PWM-chopper的吗?
2396|0
 楼主| someontime 发表于 2013-1-9 20:54 | 显示全部楼层 |阅读模式
**中讲到:
The PWM-chopper submodule allows a high-frequency carrier signal to modulate the PWM waveform
generated by the action-qualifier and dead-band submodules. This capability is important if you need
pulse transformer-based gate drivers to control the power switching elements.
不知道谁用过这个功能?做开关电源时,怎样使用这个功能驱动MOS管?
