串口通信,VB单片机发给上位机程序接收【有程序】
8302|16
 楼主| kufan 发表于 2013-1-13 16:07 | 显示全部楼层 |阅读模式
AT89S52
下面是下位机部分程序(其他功能已完毕)
void init_serialcomm( void )
SCON = 0x50 ; //SCON: serail mode 1, 8-bit UART, enable ucvr
TMOD |= 0x20 ; //TMOD: timer 1, mode 2, 8-bit reload
PCON |= 0x80 ; //SMOD=1;
TH1 = 0xFA ; //Baud:9600 fosc=11.0592MHz
IE |= 0x90 ; //Enable Serial Interrupt
TR1 = 1 ; // timer 1 run
//串口发送一个字节
void Uart_SendChar(unsigned char dat)
SBUF = dat; //待发送的数据写入缓冲区
while(!TI); //等待发送完成
TI = 0; //清零发送标志位
//串口发送一个字符串
void Uart_SendString(unsigned char *datc)
    while(*datc != '\0')
            Uart_SendChar(*datc);
              datc++;
//串口接收中断函数
void serial () interrupt 4 using 3
if (RI) //RI==开始接收
unsigned char ch;
RI = 0 ; //软件RI=0
ch=SBUF;
if (ch> 1 )
count3= 0 ;
inbuf2[count3]=ch;
else
count3++;
inbuf2[count3]=ch;
下面是VB部分     mscomm  setting部分已设置了9600,n,8,1
Private Sub cmdConnect_Click()
    '查找指定端口
    Dim i As Integer
    For i = 1 To 16
        If optComPort(i - 1).Value = True Then
            ComPort.CommPort = i
            Exit For '跳出循环
        End If
    Next
    If ComPort.PortOpen = True Then ComPort.PortOpen = False  '如果端口打开则先关闭
    ComPort.PortOpen = True  '然后打开
    '状态信息
    lblStatus = "已连接..."
    ''Text1.Text = "EXIT"
    cmdConnect.Enabled = False
    cmdDisconnect.Enabled = True
End Sub
Private Sub cmdDisconnect_Click()
    '断开连接
    lblStatus = "已断开..."
    cmdDisconnect.Enabled = False
    cmdConnect.Enabled = True
End Sub
Private Sub cmdExit_Click()
    '先断开端口再退出程序
        Unload Me
    End
End Sub
Private Sub Form_Load()
    Dim iComPort As Integer
    '错误陷阱
    On Error GoTo CommErrorHandle
    '尝试列表存在端口
    For iComPort = 1 To 16
        ComPort.CommPort = iComPort '指定端口号
        If ComPort.PortOpen = True Then ComPort.PortOpen = False '如打开先关闭
        ComPort.PortOpen = True  '尝试打开
        ComPort.PortOpen = False '确认成功关闭
    Next
    '端口配置
    ComPort.InputLen = 1    '1 个字符产生接收事件
    ComPort.RThreshold = 1  '1 个字符产生接收事件
    '跳出错误
    Exit Sub
CommErrorHandle:
    '68   = 设备无效
    '8002 = 端口号无效
    '8012 = 端口无法打开
    If Err = 68 Or Err = 8002 Or Err = 8012 Then
        '端口无效时则禁止单击连接按钮
        optComPort(iComPort - 1).Enabled = False
    End If
    '继续错误
    Resume Next
End Sub
Private Sub Form_QueryUnload(Cancel As Integer, UnloadMode As Integer)
    '断开连接并退出
End Sub
Private Sub Text1_Change()
Text1.Text = ComPort.Input
End If
End Sub
单片机发送的灯不断闪,证明是发送的,现倾向于接收端出现错误,附上位机程序
airwill 发表于 2013-1-13 20:01 | 显示全部楼层
是否借助示波器, 串口调试工具来帮助你, 寻找问题到底真哪里?
 楼主| kufan 发表于 2013-1-13 20:12 | 显示全部楼层
很困扰啊,求帮助
lzqxs89 发表于 2013-1-13 23:44 | 显示全部楼层
关于搞单片机通信方面的开发,是不是要求自己会写通信调试的上位机程序啊?
airwill 发表于 2013-1-14 08:49 | 显示全部楼层
关于搞单片机通信方面的开发,是不是要求自己会写通信调试的上位机程序啊? ...
我认为并没有这个要求, 毕竟是两个领域.
不过有时间和机会的话, 适当了解和学习一下, 对单片机编程也有帮助.
很想帮一下楼主, 不过我的上位机用的是 C++ Builder. 没有玩过 VB.
 楼主| kufan 发表于 2013-1-14 09:05 | 显示全部楼层
不过有时间和机会的话, 适当了解和学习一下, 对单片机编程也有帮 ...
坛子里有玩过VB的麽。版主没玩过没,我看估计没人帮我了
airwill 发表于 2013-1-14 09:25 | 显示全部楼层
坛子里有玩过VB的麽。版主没玩过没,我看估计没人帮我了 ...
坛子里的高人有的是, 不过未必都有时间.
其实:
1. 书本是最好的老师.
2. 要善于利用工具来帮助自己
建议借助示波器, 串口调试工具来帮助你寻找问题
江枫渔火 发表于 2013-1-14 09:39 | 显示全部楼层
网上这种资料好多,可以上网搜索。
首先要知道具体什么问题,什么原因。可以通过调试很容易确定。最好你去下载一个串口监视工具,去看看系统是否如你所愿的让你控制了指定端口。如果没有监视工具,那就自己查看自己上位机软件中,具体打开了哪个串口,参数是否准确。如果串口都没设置对,那搞什么都白费
airwill 发表于 2013-1-14 12:12 | 显示全部楼层
推荐楼主去看一看这一帖:  https://bbs.21ic.com/icview-286228-1-1.html
bruceding 发表于 2013-1-14 13:04 | 显示全部楼层
End If
这样接收?用text change触发?
建议先用串口大师接收看看,以判断到底是单片机还是上位机的问题。
T_X_T 发表于 2013-1-14 16:07 | 显示全部楼层
上位机用MFC弄的
眼不见心不烦 发表于 2013-1-29 14:57 | 显示全部楼层
你这个上位机的VB程序 不需要MScomm这个控件吗 我看你的VB工程里面好像没有用啊
加油吧小鱼儿 发表于 2013-1-29 21:14 | 显示全部楼层
fengjiex 发表于 2013-8-6 09:09 | 显示全部楼层
不知楼主“trdata”这个数组是什么意思?
qzc13457 发表于 2013-8-6 09:58 | 显示全部楼层
先用串口助手调好了再写上位机
xiaolong2013 发表于 2014-5-30 16:07 | 显示全部楼层
很不错
fbzsn 发表于 2015-4-8 22:44 | 显示全部楼层
谢谢分享!学习学习。
