求助:各位大哥 关于3972电机驱动问题?
2212|0
 楼主| wangharry 发表于 2008-2-20 13:52 | 显示全部楼层 |阅读模式
小弟 用89c2051驱动3972电机芯片 用ME-52硬件仿真给出汇编小弟对汇编不了解
代码如下:
#include <reg51.h>
#define uchar unsigned char
#define drv_ref 0
#define drv_rng 1
#define drv_mod 0
#define drv_word0 0
#define drv_word1 1
sbit clockp=P1^7;
sbit datap=P1^6;
sbit strobp=P1^5;
sbit clockt=P1^4;
sbit datat=P1^3;
sbit strobt=P1^2;
uchar pan_dac1;
uchar pan_dac2;
uchar tilt_dac1;
uchar tilt_dac2;
uchar pan_phs;
uchar pan_mode;
uchar num_step;
long  pan_word0;
long  pan_word1;
long  tilt_word0;
long  tilt_word1;
void wrtwords(long bits)
    uchar word;
    long select;
    strobp=1;
    strobp=0;
    select=0x00040000;
    for(word=0,clockp=1;word<19;word++)
        clockp=0;
        if((bits&select)>0)datap=1;
        else datap=0;
        select=select>>1;
        clockp=1;
    strobp=1;
void write_word0(uchar xx)
    pan_dac1=(xx&0x1f)<<1;
    pan_dac2=((31-xx)&0x1f)<<1;
    pan_phs=xx>>5;
    if(pan_phs==0) pan_phs++;
    if(pan_phs==3) pan_phs--;
    pan_word0=pan_phs;
    pan_word0=pan_word0<<13;
    pan_word0|=pan_dac2<<7;
    pan_word0|=pan_dac1<<1;
    wrtwords(pan_word0);
void write_word1()
    pan_word1=0x00040667;
    wrtwords(pan_word1);
void delay(int xx)
    for(;xx>0;xx--);
void main()
    write_word1();
    for(;;)
        delay(30000);
        write_word0(num_step);
        if(num_step++>126) num_step=0;
