74hc595的c51驱动程序
2303|0
 楼主| ledrgb 发表于 2008-7-30 22:59 | 显示全部楼层 |阅读模式
//带锁存功能的串入并出芯片。这里给出74hc595的c51驱动程序。
//定时器晶体振荡器11.0592M.
#i nclude<reg51.h>
#i nclude <INTRINS.H>
#define uint unsigned int
#define uchar unsigned char
#define nop() _nop_();_nop_();
sbit CLK=P2^0;
sbit DAT=P2^1;
sbit RCLK=P2^2;
//sbit CS=P2^3;
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff};//0-9,-,全灭
void sendbyte(uchar byte)
        uchar num,c;
        num=tab[byte];
   for(c=0;c<8;c++)
         CLK=0;
         DAT=num&0x80;
         num=num<<1;
         CLK=1;
//         RCLK=0;
//         nop();
//         nop();
//         RCLK=1;
void out595(void)
        RCLK=0;
        nop();
        RCLK=1;
void display(uchar word)
uchar i,j;
i=word/10;
j=word-10*i;
sendbyte(j);
sendbyte(i);
out595();
main()
    while(1)
     display(19);
     display(86);
    while(1);
