急求教一个关于Keil uVision3的问题
3783|12
 楼主| 攀登者 发表于 2008-9-10 12:38 | 显示全部楼层 |阅读模式
在中Keil uVision3用printf("Hello C51 ")语句,我编译、运行之后打开串口看仿真结果却什么都没显示!请问一下为什么这样?谢谢
#pragma
#include<reg51.h>
#include<stdio.h>
void main()
SCON=0X50;
TMOD|=0x20;
TH1=0xf3;
TR1=1;
T1=1;
printf("Hello C51 ");
while(1){}
jiangrh 发表于 2008-9-10 13:04 | 显示全部楼层
RE
#include<reg51.h>
#include<stdio.h>
void main()
  SCON=0X50;
  TMOD|=0x20;
  TH1=0xf3;
  TR1=1;
  TI=1;   //此处T1
 while(1);
 楼主| 攀登者 发表于 2008-9-10 13:23 | 显示全部楼层
这个问题困扰我两天了 ,希望高手们能指点一下小弟!不胜感激!!!!
xuyaqi 发表于 2008-9-10 14:49 | 显示全部楼层
二楼不是已经给你解决了!你没看到!
 楼主| 攀登者 发表于 2008-9-10 15:38 | 显示全部楼层
问题解决 谢谢上面的两位高手!!!!我还有个问题想请教 要是运行我下面的程序后打开串口能看到仿真结果吗?谢谢
#include <reg51.h>
#include <intrins.h>
#include <stdio.h>
#include <absacc.h>
#define uchar unsigned char
main ()
{uchar code valuecode1[]={
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0xff,0xf0,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x18,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xbf,0xff,0xdc,0x00,0x01,
0x80,0x00,0x1f,0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xbf,0xff,0xbc,0x00,0x01,
0x80,0x00,0x30,0x00,0x01,0x80,0x00,0x00,0x00,0x00,0x01,0x7f,0xff,0xb8,0x00,0x01,
0x80,0x00,0x30,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x01,0x7f,0xff,0x78,0x00,0x01,
0x80,0x00,0x19,0xff,0xfe,0xc0,0x00,0x00,0x00,0x00,0x02,0xff,0xff,0x70,0x00,0x01,
0x80,0x00,0x18,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x02,0xff,0xfe,0xf0,0x00,0x01,
0x80,0x00,0x0c,0x01,0xff,0x06,0x00,0x00,0x00,0x00,0x05,0xff,0xfe,0xe0,0x00,0x01,
0x80,0x00,0x0c,0x7f,0xd0,0x20,0x00,0x00,0x00,0x00,0x05,0xff,0xfd,0xe0,0x00,0x01,
0x80,0x00,0x06,0x00,0x0f,0xb0,0x00,0x00,0x00,0x00,0x0b,0xff,0xfd,0xc0,0x00,0x01,
0x80,0x00,0x06,0x03,0xfc,0x10,0x00,0x00,0x00,0x00,0x0b,0xff,0xfb,0xc0,0x00,0x01,
0x80,0x00,0x03,0x1f,0x00,0x18,0x00,0x00,0x00,0x00,0x17,0xff,0xfb,0x80,0x00,0x01,
0x80,0x00,0x03,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x17,0xff,0xf7,0x80,0x00,0x01,
0x80,0x00,0x01,0x80,0x00,0x0c,0x00,0x00,0x00,0x00,0x17,0xff,0xf7,0x00,0x00,0x01,
0x80,0x00,0x01,0x80,0x00,0x04,0x00,0x00,0x00,0x00,0x09,0xff,0xef,0x00,0x00,0x01,
0x80,0x00,0x00,0xc0,0x00,0xf6,0x00,0x00,0x00,0x00,0x06,0x7f,0xee,0x00,0x00,0x01,
0x80,0x00,0x00,0xc0,0x03,0xc2,0x00,0x00,0x00,0x00,0x01,0x9f,0xde,0x00,0x00,0x01,
0x80,0x00,0x00,0x06,0x00,0x3b,0x00,0x00,0x00,0x00,0x00,0x67,0xdf,0x00,0x00,0x01,
0x80,0x00,0x00,0x06,0x00,0xe3,0x00,0x00,0x00,0x00,0x00,0x19,0xbf,0x00,0x00,0x01,
0x80,0x00,0x00,0x30,0x03,0x8e,0x00,0x00,0x00,0x00,0x00,0x06,0x3f,0x00,0x00,0x01,
0x80,0x00,0x00,0x30,0x06,0x3c,0x00,0x00,0x00,0x00,0x00,0x01,0xff,0x00,0x00,0x01,
0x80,0x00,0x00,0x18,0x00,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x01,
0x80,0x00,0x00,0x18,0x03,0xc0,0x00,0x00,0x00,0x00,0x00,0x0f,0x7f,0x80,0x00,0x01,
0x80,0x00,0x00,0x0c,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x1f,0xc0,0x00,0x01,
0x80,0x00,0x00,0x0c,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x07,0xe0,0x00,0x01,
0x80,0x00,0x00,0x06,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0x1f,0xe0,0x00,0x01,
0x80,0x00,0x00,0x07,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x3f,0xc0,0x00,0x01,
0x80,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0xff,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0xfc,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xf0,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xc0,0x00,0x00,0x01,
0x80,0x05,0x40,0x88,0x04,0x01,0x08,0x00,0x00,0x0a,0x81,0x10,0x04,0x00,0x20,0x01,
0x80,0x79,0x21,0x08,0x02,0x21,0x49,0x00,0x00,0xf2,0x42,0x10,0x04,0x47,0x10,0x01,
0x80,0x09,0x07,0x7f,0xf7,0xaa,0x00,0x00,0x12,0x0f,0xbe,0x7f,0xe5,0xfe,0x01,0x80,
0x7f,0xf4,0x51,0x08,0x81,0x2c,0x00,0x00,0xff,0xe8,0xa2,0x44,0x47,0x00,0x01,0x80,
0x09,0x04,0x61,0x08,0x81,0x7f,0x00,0x00,0x12,0x08,0xc2,0x7f,0xc5,0x4a,0x01,0x80,
0x0b,0x24,0x51,0x08,0x83,0x81,0x00,0x00,0x16,0x48,0xa2,0x44,0x45,0x6a,0x01,0x80,
0x1d,0x47,0xc9,0x05,0x05,0x01,0x00,0x00,0x3a,0x8f,0x92,0x44,0x47,0x52,0x01,0x80,
0x68,0x84,0x49,0x05,0x05,0x7f,0x00,0x00,0xd1,0x08,0x92,0x7f,0xc5,0x6a,0x01,0x80,
0x09,0x94,0x41,0x02,0x01,0x01,0x00,0x00,0x13,0x28,0x82,0x44,0x05,0x4a,0x01,0x80,
0x0e,0x57,0xc1,0x0d,0x81,0x01,0x00,0x00,0x1c,0xaf,0x82,0x04,0x29,0x42,0x01,0x80,
0x38,0x34,0x4e,0x70,0x71,0x7f,0x00,0x00,0x70,0x68,0x9c,0x03,0x9c,0x7e,0x01,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80 ,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xff ,
 uchar j,n,i,s1;
 for (j=0;j<32;j++)
    for(i=0;i<16;i++)
     {n=valuecode1[s1++];
      printf("%d",n);}
箫笑 发表于 2008-9-10 15:46 | 显示全部楼层
能不能看到效果不是自己试一下就知道了吗????
不过第一眼看上去,s1这个变量的初值不会是0的,局部变量是不会自动初始化的。
 楼主| 攀登者 发表于 2008-9-10 16:11 | 显示全部楼层
Keil uVision3
我试过了,编译能通过,运行仿真时Keil uVision3的提示窗口显示代码过大,Keil uVision3软件我这几天才学习的,所以我想请高手帮我看一下是不是软件还要设置其他东西啊 谢谢
gjg191 发表于 2008-9-10 16:29 | 显示全部楼层
o
你不会用的是限制版吧 找个**板的
 楼主| 攀登者 发表于 2008-9-10 16:33 | 显示全部楼层
Keil uVision3
我用的就是**版的啊
torch888 发表于 2008-9-10 16:48 | 显示全部楼层
RE
你的数组太大的缘故吧,把数组减小试试
 楼主| 攀登者 发表于 2008-9-10 17:00 | 显示全部楼层
Keil uVision3
我已经把数组减少了 但运行仿真后打开串口看还是什么东西都没有,这是为什么呢?
xuyaqi 发表于 2008-9-10 22:43 | 显示全部楼层
我改了一下,自己去对比吧。
#include <reg51.h>
#include <stdio.h>
#include <absacc.h>
#define uint  unsigned int
main ()
  uchar n;//,s1;
  uint i;
  SCON=0X50;
  TMOD|=0x20;
  TH1=0xf3;
  TR1=1;
  TI=1;   //
  for(i=0;i<1024;)
   n=valuecode1;//
   printf("%u ",n);
   i++;
  while(1);
1248 发表于 2008-9-10 23:03 | 显示全部楼层
呵呵!
有时问题很简单,可是找半天都找不问题所在。
