| 自己有一个东东,有9个引脚,用了7个,每个引脚功能描述如下 1:N_Boot_link ,Enables field programming of internal processor
 5V wrt DGND, active low signal ,0V when in use.
 2: + link_Ser_out,RS422 Signal,+5V,0V
 3: - link_Ser_out,RS422 Signal,+5V,0V
 4: +link_Ser_In ,RS422 Signal,+5V,0V
 5: -link_Ser_In ,RS422 Signal,+5V,0V
 6: N_Wdogdis ,Stops Watchdog from timing out during field programming of the internal    processor,5V wrt DGND,active Low signal,0V when in use
 7: Link_Reset,Reset processor, 0V,active high signal ,5V wrt DGND when in use
 我现在想用一个合适的读写电路和软件,对这个东东内部的程序进行读写,在此求助各位高手支招。谢谢
